Previous in Forum: Capacitor Mounting   Next in Forum: Power Angle
How Loaded are HV Cables?
03/15/2010 3:33 PM
Hello, I was looking at CR4 forum: could you help me with this electrical question please:
On a HV network if I have a cable for which I know the sending and recieving MW/MVA and MVAr (say between two buses), how can I describe/define how 'loaded' the cable is if I compare it to a parallel cable that has slightly different values?
Cheers.
Noel.
Re: How Loaded are HV Cables?
03/27/2010 1:21 PM
Dear Guest,
Your question is not cear. What do you mean by " PARALLEL CABLE THAT HAS SLIGHTLY DIFFERENT VALUES." What do you mean by DIFFERENT VALUES.
Please clarify. I presume, that internal resistance of the cable(s) is/are varying and has considerable difference. Under these conditions, voltage drop being common for all the cables, the current flow will be decided by the voltage drop.
I am not sure whether you understand this.
DHAYANANDHAN.S,
CR4 MEMBER,
INDIA.
03/28/2010 2:58 PM
Thanks for your response.
I was just trying to understand what characteristics made a cable 'loaded' in terms of its abilty to transfer power ie what's the difference between a lightly loaded cable and a heavily loaded cable.
I understand your response. Thanks again.
N
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
