I'm really needing help. I have a 1986 Ford Ranger pickup with 2.9 V-6
The engine died while driving and now the fuel pumps won't run.
I have checked the circuits and from the relays (there are 2; 1 electric and 1 vacuum operated) to the pumps everything is as it should be.
The problem is that the EEC will not turn on the relays. They should come on for 3-5 seconds with the key on to pressurize the system and then again when the engine is cranking or running, with the vacuum switch turning off the starting side when the engine starts.
These are triggered from pin 22 and the ECU but I get voltage at that pin with key on-engine off, as well as the other side of the relay trigger. (? pin 22 should switch to ground to activate pumps~I think?)
Jumpering the fuel pumps will make them run but the engine will still not start even though I still have spark.
There must be something getting the wrong signal to the ECU. I put this ECU on another vehicle and it ran fine and a new ECU on this one and get the same symptoms.
Anyone have a clue or suggestion?
