Previous in Forum: Water Contamination in Petrol / Gasoline   Next in Forum: 1986 Ford Ranger Pickup Won't Start
Replacing EPROMs on Chevy Vans
03/15/2010 10:31 AM
Has anyone out there been sucessful replacing EPROM units
on Chev Vans ? GM stopped making EPROMs specific to their
lineup , making obtaining new replacement chips impossible.
venture1
Re: Replacing EPROMs on Chevy Vans
03/15/2010 5:47 PM
Yes, Get your parts person to look up the prom # if you don't have a book. MOST were superseded and the original # is not available. What year is it? What engine / trans. I just have a freind at chevy and have had van and pickup issues since 93
03/16/2010 10:03 AM
1992 G30 - 5.7 litre (350) automatic .
03/16/2010 8:27 AM
Hello Venture 1,
I can help you find the proper Eprom if you provide engine /trans. details, year and make of Van.
Most ECM modules can be removed and Eprom just plugs into a circuit board socket. There is a notch on the end of the chip, make sure it goes back on in the same orientation.
Note: The Eprom only stores a program that is character-specific to your vehicle. This allows GM to make one ECM module to facilitate many car or truck makes.
You should be able to use the original Eprom in a new or used ECM, providing the ECM has the same Model Number. Unless the Eprom is damaged or has been erased with ultra-violet light through glass access window it should be good. If the program for your Eprom is obtained, you can compare the check sum of the program to the original Eprom check sum using an EPROM burner and software.
There some companies that make Eprom upgrades for high-performance applications.
Let me know vehicle information..
Thank you in advance
Best Regards, Tim
04/14/2010 10:44 AM
It's a 1992 Chev G30 . 5.7 litre (350) automatic , 2wd .
It's not throwing any codes .
Mark Steele
venture1
03/16/2010 11:21 PM
Are you throwing any codes now? These were the first years that the TRANSMISSION LOAD Sensor (collar) ran the computer, not vacuum.
Anonymous Poster (2); ray cockrell (2); venture 1 (1)
You might be interested in: Amplifier and Comparator Chips, CPU Chips
