Previous in Forum: Piping Materials and Air Compressors   Next in Forum: Calculating Compressed Air Consumption in an Existing Plant
Coupling System for LPG Storage and Dispatch
03/16/2010 11:06 AM
hii guys
presently i am working in lpg storage and de3spatch terminal.In truck loading truck connection and disconnection time is taking too much time.i would like to know about if there is any coupling system that can be used to reduce truck connection and disconnection time.
Re: coupling sytem that can be used in lpg
03/16/2010 11:21 AM
What coupling system is in use already, so as not to duplicate with guesswork?
Why does the existing system take as long as it does?
What other things might be done to speed-up the logistics in this area other than change an otherwise presumably-technically-satisfactory coupling system for something else?
Good Answers: 141
03/16/2010 3:43 PM
Everything bigger or more powerful: or some of the units: Pump, hose, coupling, No bigger truck!!
Plenty of room here
03/16/2010 4:31 PM
As far as I know all vehicles use standard coarse thread screw on type fueling connectors. They are either the smaller style that propane powered fork lifts and other construction machines use or the larger style like bulk tanks used for home heating use.
If you cant spare the 3 -4 seconds of time it takes to screw one of those on or off then you probably need to seriously invest some efforts into proper time management techniques or employee hand-eye skills training (Righty tighty, lefty loosey).
More information on what you are using and why things take too long would be more useful.
Good Answers: 141
Re: Coupling System for LPG Storage and Dispatch
03/16/2010 5:09 PM
Is there no standard available? I know everything has to be spark free and grounded to avoid static electricity build up. I guess all trucks should have similar couplings? In the tank on the truck you have a pressure to overcome. This pressure is only depending on the temperature. Or you increase your pump pressure, or you cool down the tank of the truck. A roof to create some shade helps a lot. Shorter distance between the truck and supply tank helps also.
Plenty of room here
Good Answers: 97
03/17/2010 2:11 AM
Your people need good training and speed is a double edged sword too little leads to accidents. I suggest you travel and observed a well trained operation and take notes also enquire of their training procedures.
03/17/2010 4:00 AM
Hello,
Well, I had worked for a cryogenic company. We bought the coupling systems for liquide nitrogen tank filling process at Air Liquide - Global company who specialize on gas supply (every gases, including liquide gases and special armature even for cryogenic apply).
Visit: http://www.airliquide.com/en/our-offer/engineering-2/air-liquide-original-spare-parts.html
Kind Regards,
Vadim
03/17/2010 7:52 AM
Abner
Register to Reply 7 comments
Abner (1); Anonymous Poster (1); bwire (1); dvmdsc (2); PWSlack (1); tcmtech (1)
