Previous in Forum: Residential Wiring - NM Cables in Fiberglass Boxes Without Clamps   Next in Forum: Trip Circuit Supervision
Megger Testing
03/16/2010 1:36 PM
how could i make megger test in a plc panel of a water treatment power station designed by schnider electric....
Thank you........Hema Eissa
Good Answers: 141
Re: Megger Testing.....
03/16/2010 2:49 PM
You can Megger anything when not connected to your PLC. Keep that Megger far away from electronics. Semiconductors don't like to be fried or overstressed with your Megger. Even the full electronic Meggers will put your circuits to risk. If you have isolation concerns, use a high (impedance) resistance Ohm meter with limited output voltage on your highest Mohm scale, and overrange display is also ok. (digits flashing)
Plenty of room here
Good Answers: 12
Re: Megger Testing
03/17/2010 12:13 AM
Yes, you can megger test; but do not forget to through the panel in to the sea after test completion!
Subramanyam
Good Answers: 141
Re: Megger Testing
03/17/2010 12:29 AM
I prefer recycling
Plenty of room here
Good Answers: 117
Re: Megger Testing
03/17/2010 3:35 AM
There you have it, do not test anything electronic
but I guess you want to test the other parts of the panel that are not electronic?
If you do , then see if you can isolate or even better remove the PLC from the panel. However I can only wonder why you'd want to megger a panel, if you are trying to test the cables, then disconnect before testing, if its the contactors, they don't really need to be tested.
So think about what you want to achieve and don't just test for the hell of it, you might break something you can't fix.
Re: Megger Testing
03/17/2010 6:07 AM
Megger the cables, sure, if it seems worthwhile or is required by local standards. Make sure they are disconnected from the panel before so doing.
DO NOT MEGGER THE PANEL!
Re: Megger Testing
03/19/2010 2:41 AM
I suggest dont megger the panel :) but insulation test it
Good Answers: 117
Re: Megger Testing
03/19/2010 3:44 AM
In reply to Guest answer No6,
the word "Megger" is a trade name, but has been used over the years as a way of saying, "let's test the insulation". The correct descriptive name is "insulation tester" for any "MAKE" of tester. It was Avo that called their first tester a "Megger" .
When you "Megger" anything you are testing the insulation, so its one in the same thing. Thought you'd like to know.
BUT..... ALL the previous comments still stand....DO NOT test the PLC/Panel without first isolating or removing the electronics, be safe not sorry!
Register to Reply 7 comments
Anonymous Poster (1); brich (2); dvmdsc (2); kvsubramanyam (1); PWSlack (1)
