Previous in Forum: What Motor Is It?   Next in Forum: MCCBs
8 comments
Indonesia - Member - Member from Indonesia Engineering Fields - Mechanical Engineering - Mechanical Engineer Popular Science - Weaponology - Weapon Fan Safety - Hazmat - Safety First! Hobbies - Automotive Performance - Tuner Wannabe Hobbies - Target Shooting - I'm a good shooter
Humming/Hissing Sound on Speaker
03/16/2010 10:39 PM
Dear engineers..
I am not an electrical engineer, but i have phenomena (lets say problem) in my computer speaker (could be related to electrical & electronics engineering). I just bought my computer speaker in Australia and i noticed the hissing or humming sound on it (both satellites and subwoofer).
The humming/hissing sound is not quite noticeable except your ear gets close to the satellite/subwoofer (the music is off or in small volume).
The things that i have done to analyze this problem are:
1. I unplugged my interconnect cable (cable that connect computer to speaker), but the humming/hissing sound keeps sounding (no changes at all). So i assumed the humming is coming from electrical power/amplifier inside the subwoofer.
2. I have given grounding cable (attach cable on one of the speaker bolts and connect it to nail on the wall), but the disturbing sound never stops.
3. I have tested the satellites on my CD player, and the result is.. The sound is just clean & clear, no humming/hissing on my satellites. But unfortunately, i have not tested along with the subwoofer, because i don't have any stock of RCA-to-RCA cable.
4. I just connected the speaker power cord to the UPS/stabilizer (to make the electrical signal more stable), but the humming keeps going!
Could you help/explain me what kind of phenomena is this? And how to solve this problem?
I know this is just minor problem (because it does not really disturb the music if the music volume is getting loud. But if your ear is very close to the speaker while the music is off, you can hear that humming/hissing sound). Please help me.
Thank you very much
Please give respectful & positive answer than insulting! Respect each other ok..
Re: Humming/Hissing Sound on Speaker
03/17/2010 6:04 AM
Any audio amplifier will have a rated signal/noise ratio, which might be given in decibels (dB).
What is happening is that the ear is so close and so well-coupled to the speaker that the noise level is becoming audible at times.
The only real solution is to replace the amplifier with one with a higher signal/noise ratio.
03/17/2010 8:29 AM
Thank you for your response PWSlack.
So, it means that my speaker is ok or normal sir? Except (as you mentioned) in its specification of signal/noise ratio.
My speaker is active speaker (the amplifier is inside subwoofer), so it is very difficult to change the amplifier with the greater signal/noise ratio.
Thank you for any explanation.
03/17/2010 11:13 PM
"2. I have given grounding cable (attach cable on one of the speaker bolts and connect it to nail on the wall), but the disturbing sound never stops."
A) This is NOT a ground, unless your wall is made of some conductive material, and is connected to earth ground! If you have 3-wire outlets, the screw holding the cover plate in place should be a good ground. B) it is unlikely that grounding the speaker frame will make a significant difference. Grounding the correct contact on the amplifier might. C) Most speaker frames are painted; you must scrape the paint off where the ground wire contacts painted metal. The same is true of anodizing on aluminum.
To me, there is a big difference between hiss and hum. Hiss is a high frequency noise with no obvious single frequency. All transistors used to have some hiss - I'm not sure if that is still true. Hum is a low frequency noise, usually at the power line frequency or twice the power line frequency. Years ago, hum commonly meant failing capacitors in the power supply, but it could also result from poor grounding.
Good luck...
03/18/2010 4:55 AM
Try turning the volume control on the speakers down to a lower level.
Then adjust the volume level on your computer louder until the volume level of the music you are listening to is satisfactory.
The add on speaker system will only amplify the signal you give it.
If the signal from the pc is low and poor then it will reproduce that poor signal.
If the signal coming from the pc is loud and strong... well you get it!!!
03/18/2010 7:36 AM
Regards.
There are some unaviodable sources of noice in eectronic components which have some effect on producing sounds [noise] e.g. thermal agitation in atoms etc etc only for researchers & designers but is info for music fans.
Others are Inducted or cnducted signals and can be minimised not altogether removed.
And Hi Input impedance also may be reason to produce Hum.
And Nail in a wal is not EARTH /Ground; but a floating wire working as an antenae.
03/18/2010 11:26 AM
first of all are you useing a personal generator? or is your house close to factory if no .disconnect the ups connected to the pc and connect it to direct mains supply(a.c) and if the noice persist there could be a faulty fan motor of the cpu. I personally have encounter such a problem.
if not disconnect the pc from mains and allow the ups to drive the pc otherwise it could be from from public utility raw power supply interferance noise.finally if the noise could not be remedise use interference suppressor cables between mains supply(a.c) to all the pc connected equipments(monitors,printer,external hard disc and ups.if the situation persist send th pc to a technician to check the power supply filters(capacitors e.t.c) of the cpu could be faulty.
03/18/2010 3:28 PM
You need to prove what is defective, if anything.
1. Disconnect the "audio system" from the PC, and take it to another room.
2. Connect an iPOD (or any MP3 player) to it, and listen to it under several volume levels. If it does that well, it is NOT the "audio system".
3. Now connect a simple stereo earphone set to the same audio output on your PC that you were going to use with the "audio system". If that works well, then:
4. You have a ground loop, or a serious RF interference problem in your computer system.
5. There are a couple or three audio outputs from most PC's. Try all of them.
03/22/2010 10:53 PM
Thank you for all replies..
I don't have any ipod, so I test it to my laptop (battery-powered), the humming (if louder) and the hissing (if silent) still no changes. But i still tested in the same room. Ok will try it to test my speaker to another room.
Oya maybe this one coul help you analyze the problem.
Actually i used wrong electrical socket. The electrical plug of my speaker is just like the following picture.
But i plug it into this kind of socket (British standard)
Could this thing make the humming & hissing sound? I haven't tried to plug it into the right socket like this
I know this is stupid plugging it into wrong socket, but i could not find the right socket so far. So i used the British socket (and luckily it is well-fitted, i know there is must be untouched surface inside because of the unmatched shape).
I need your comment please. Thank you very much.
Register to Reply 8 comments
Anonymous Poster (1); dkwarner (1); Haajee (1); Iruero.o. James (1); Premium (2); PWSlack (1); WoodwardDL (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Sound Cards
