Previous in Forum: What is Variable Pump Control?   Next in Forum: Pipe Sizes and Compressor Discharge Lines
Dual Grade Wall Thickness Calculation 316/316L
03/17/2010 1:20 AM
why we are going for dual grade materials?
for wall thickness calculation in dual grade materials.
which properties to be considered.
Re: Dual Grade Wall Thickness Calculation 316/316L
03/19/2010 9:22 AM
I think you will find that there is an overlap in the requirements for chemical composition of 316 and 316 L. The L is generally taken to mean Low carbon. The problem is taht if you weld a stainless having more than a certain level of carbon, carbides may be formed at the surface and this initiates pitting corrosion in hostile environments - e.g sea water, sea water spray or even salt-laden fog or air. In fact environment having some chloride presence. Hence 316 L is often specified.
Since 316L has a lower strength (lower tensile and lower .2% proof stress which is often referred to as a yield stress) then the allowable stress values for 316L should be used.
There is a lot more to it so if you are doing anything for a critical application where damage could endanger life, then make sure you have your calculations checked by a piping engineer and have a materials expert confirm your material selection.
03/22/2010 6:37 AM
As per my understanding we use Dual grade materials for interchangability.
Properties as below.
316/316L - 0.4% carbon as per 316L and tensile/yield strength as per 316.
for wall thickness calculation purpose
we need to consider Pressure/ temperature values of 316 in B16.5 and stress valves of 316L in ASME B31.3.
if my statement is wrong please correct me.
regards
viki
Register to Reply 2 comments
