Previous in Forum: ISO Welding Symbol Chart   Next in Forum: KW Calculation for Small, High-Pressure Centrifugal Fan
Variable Speed Drive for Krebs Pump
03/17/2010 6:55 AM
I would like to know what are the benefits of installing the VSD on the coal correct medium pumps.how can I justify the savings
centrifugal pump model 250/200krebs726 , 10/8/24
motor rating 275 kW
Actual motor output average 245kW at sg 1.73
flow 750m3 /h
Re: benefits of installing the Variable Speed Drive on the Krebs pump
03/17/2010 7:12 AM
It depends upon the electricity tariff in use. If a peak-demand tariff is in use then the VSD will pay for itself in weeks as a result of softer motor-starting and the lower peak demand that results.
If a per-kWh tariff is in use, the VSD might be programmed so as to reduce the terminal voltage when the pumps are running below maximum demand.
Re: Benefits of Installing the Variable Speed Drive on the Krebs Pump
03/17/2010 9:56 AM
You mention that your (unspecified) pumpage is a presumably crushed coal/water slurry, specific gr 1.73, at a rate of 730m^3/hr. You do not mention if your operation requires a constant or veriable Q (pump output) If you require a variable pump output, then the installation of a VSD is essential and the savings (if any) are secondary. If you do not require a variable Q, then why speak of a VSD in the first place. To use a VSD just to obtain a soft start is neither practical nor cost effective. There are other technologies specially designed for this purpose, more efficient and less costly.
You might be interested in: Motor Test Equipment, Motor Repair Services
