Previous in Forum: NPSHR 40000 Hrs for Centrifugal Pumps   Next in Forum: Flanges for Piping Class 900
Torque Required to Run a Roller
03/18/2010 3:34 AM
Hallo,
I have a problem
i want to know why my Invertor is burn.
for Load
use F=ma = 5000*.167= 835 N
and Torque= F*r = 835 * 0.20 = 167 N.m
for Motor
Omega W=n * 2pi/60 = 2990*2*pi/60 = 313
Torque = P / W = 2600 Watt/313 = 8.31 N.m
ration of wheel = 50:1 then 8.31*50 = 415 N.m
My Motor have Torque = 415 but load only 167 N.m. Why my invertor is broken ?
or i have miss calculate
Re: torque required to run a roller
03/18/2010 6:09 AM
have you taken care of friction et al while calculating the required power?
What about the motor starting current (typically 5-7 times FLC unless you have VFD or other starting mechanism)
When did it burn? at start or later?
03/18/2010 9:14 PM
I used Motor
for star-delta start
star- 230 volt 50 Hz 2.2 kW 6.2 A
delta- 400 volt 87 Hz 2.6 kW 6.2 A
but i used invertor that mean motor have alway 2.6 kW isn't it?
I think it overload while acceleration from 0 to 0.5 m/s
04/27/2010 2:29 AM
In Star it should be 400 V 50 Hz
In Delta it Should be 240 V 50 Hz
What are U using a VFD?
In Delta are U using 87 Hz?
What is the application of this roller?
Please mention the Motor Nameplate and Inverter Specifications?
Waiting for Ur reply
Register to Reply 3 comments
Anonymous Poster (1); dewz (1); Zalaid Khan (1)
