Previous in Forum: Shunt Capacitors and Reactive Power   Next in Forum: Neutral to Earthing Voltage
Neutral Isolation
03/18/2010 7:02 AM
For Isolating neutral of normal power supply when D.G is running ( Vice versa also ) which is prefered in the below two alternatives.
1. Installing a 4 pole breaker at in the normal incomer as well as D.G incomer.
2. Installing a contactor for both the neutrals so that one remains energised when the other is open.
Re: Neutral Isolation
03/18/2010 6:13 PM
Why would you want to isolate the neutral from the poswer supply?
Good Answers: 244
03/18/2010 10:51 PM
There are some interesting discussions on this topic already available in CR4. These are some of them and you can find more. Hope it will help.
http://cr4.globalspec.com/thread/10957
http://cr4.globalspec.com/thread/42960
http://cr4.globalspec.com/thread/35491
http://cr4.globalspec.com/thread/9225
- MS
Register to Reply 2 comments
