Previous in Forum: Prestressed Concrete Pipe   Next in Forum: RC Structure Strength
31 comments
Monolithic Domes
03/19/2010 8:54 AM
What formulas are available for designing a monolithic dome, say 200' diameter x 40' hi? Rebar size and placement. How is the stryrofoam applied to assure 4" thickness? How is the styrofoam strong enough to hold the rebar in place? What is the compressive strength of shotcrete, f'c? How can it be applied to assure a specified thickness, say 4"? Inasmuch as the shotcrete will have a rough surface, how is a pleasing surface applied over it? What is the best roofing material to apply on the exterior surface, and how is it made to adhere to the styrofoam under the sheet? Are there any codes that stipulate the design of such domes?
Re: Monolithic Domes
03/19/2010 11:37 AM
OH God, I hope you're not building a sweat lodge!
I know nothing about this type of construction, but these guys might:
Monolithic Dome Institute - The Orion
Good Luck.
03/19/2010 7:27 PM
Lyn, its funny you should ask; as that's exactly what I'm up to. I'm going to charge $12,000, but for you, I'll make it $10,000; since you're the first one to step up. <g>
PS: Thx for the link.
03/19/2010 7:48 PM
Depending where you are, get to know the local code/permitting folks. Unless, of course, you are in the middle of a 100 acre compound.
Good luck.
Good Answers: 97
03/20/2010 10:08 AM
You will find extensive resources here:
http://www.binisystems.com/dantebini.html
03/20/2010 10:44 AM
bwire, thx for the link. I never heard of such a system!
Good Answers: 179
03/20/2010 12:40 PM
Wowsers flyinghigh, are you building another Super-dome out in the AZ desert? *LOL* -+*
Question for you: Are you building this dome yourself or just designing it or both? Designing it will depend ultimately on how it's going to be built.
Here's the short of how to build a dome one way. There are other construction methods.....
Have you even seen a precast concrete tank being constructed, such as a Natgun or Preload tank? That'd be the easiest way to construct a dome, especially with the span you're looking at!Natgun precast reinforced concrete dome panels...the entire dome being segmented into 3 or 4 circumferential rows with many pie slices, all made on the ground in very precise casting beds, one atop of the next slice and so on and so on....you end up with a stack of identical pie slices (actually not exactly a pie slice but more like truncated pie slices with 4 sides). Each row is separated by heavily reinforced circumferential rings that are later grouted solid.
Okay, the way Natgun does it is once they finished cast the dozens of pie slices they make sure all of the test results come back satisfactorily...and they make a batch of no less than 6 concrete test cylinders for each truck of premix....ditto with field tests done for each truck..air entrainment, time since dispatch, concrete temp., ambient air temp, & slump ,and how much mid-range plasticizer (in Oz.) added to the truck's load only at the job site and only at the express order by Natgun's Concrete Supervisor. The pie slices are then cured on-site for I believe no less that 28 days. they're protected too from the elements and accidental damage. Concrete hot boxes are provided on the site for all of the cast concrete cylinders, but taken at the correct times back to the lab for compression breaks.
Once the pie slices pass the muster of the Natgun Engineer's and site Supervisor as well as the project Engineer of Record, they are then erected upon steel towers (false works) much like scaffolding, but lots of them and fully adjustable at the base and summits. Once the pie slices are in correct position, the spaces between them are grouted solid and so are each of the 3 or 4 circumferential compression rings i mentioned above. After all of the grouted is completed then the concrete tension ring at the base of the dome (and at the top of the precast concrete walls) is wire wound with high tensile strength steel wire, then anchored and a shotcrete layer applied. This wire winding and Shotcrete may be done up to at least a dozen or so individual layers. With all of the tensile load applied down at the tension ring the end result is that the entire dome structure is then placed into compression....and whhhaaaa laaaaa you have a structurally sound dome!!!!
Formulas eh? I'll have to look for them...ummm dig them up and get back to you. It's not something you do every day!
For the span you're looking at, 4-inches of reinforced concrete may be too thin and you may have to bump it up to say around 5.5" to 6.6". there is a rule of thumb applied, but I don;t remember it off hand at the moment.
When designing a dome, make sure you use a good 3D FEM program that also includes a decent reinforced concrete design and analysis module to get it all right, okay???? It'll cost you a good amount to procure and license.
03/20/2010 2:32 PM
Good morning, CaptMoosie, thx for your note.
Apparantly someone wants to build one. The school district in Overgaard & Payson each built one.
My job will be to design it. Material, size, placement of rebar, concrete, shotcrete, grouting, wall, ring beam, dome. My guess is they're going to use the MDI process (Monolithic Dome Institute). BTW, does shotcrete come in different strengths, f'c, like 4000 psi, or does one suffer a degradation due to the fluidity of the material? I would think the Binisystem is much more expensive.
I'm not familiar with the Natgun process. Do they weld the rebar prior to grouting the segments?
Since the arc of 1/2 the dome is almost flat because of the huge radius, I tried using the formula for a simply supported reinforced beam per p42 of Reinforced Concrete Design, Spiegel, 4th ed., but as expected, it came out negative for no matter how much steel or how thick the concrete was.
I am going to try to apply Roark's formula 1b, Table 9.3, p336, Circular Arches, 7th ed., but its not for a composite beam, so to what advantage?
Per your advice, I'm going to investigate an FEA software solution. Thx again.
03/20/2010 4:11 PM
Use an engineer from Monolithic. Videos by Monolithic: Good academic videos, with information from Monolithic. I like, some of the conceptual designs, especially the church and other public buildings. http://www.youtube.com/watch?v=2yJfcnIFYqg&NR=1 http://www.monolithic.com/topics/homes
Hope this helps, Adam Darriau
R. Adam Darriau RAD Building and Design San Francisco, CA.
03/21/2010 12:01 PM
Good morning CR4radarriau. Thx for responding. I was interested in becoming the design engineer. I wonder if Monolithic's 5-day course will teach you this, or is it more for how to build it after you receive the plans. I will contact them next week.
Good Answers: 179
03/20/2010 11:01 PM
Hello Highflying,
Wow, lots of questions to answer!
The reinforcing steel extending out from the edges of the precast concrete dome segments are mechanically anchored to the rebar from the adjoining segments.....rebar lengths extending out of the segment as per design to provide proper lap length.
I see you're using the late Doc Len Spiegal's & George Limbrunner's (of Hudson Valley Community College in Troy, NY) textbook! Great reinforced concrete textbook!!!! I received my AAS Civil Eng, Tech. degree there and had both Professors for several classes some 30+ years ago. Both were tremendous influences on me and my education...both wonderful men and human beings! Too bad that Doc Spiegal has passed away some time ago, not long after he retired from teaching. Truly sad.
Ummm, I wouldn't be using the beam formulas from Spiegel's textbook to design a dome structure because they don't apply.....a dome usually has an elliptical or spherical curvature and isn't level like beam. Domes are classified under "Thin Shells" just like barrel vaults ,etc.
May I suggest the following textbook for you to begin your study of dome design: "Structural Engineering Handbook", by Gaylord & Gaylord, McGraw-Hill Publishers, 1968. Refer to Chapter 20. Beware that the theory of domes is not for the faint hearted and is very involved. Once you understand the fundamentals of dome analysis and design, then you should have any problems working a high-grade FEA program designing the dome. You can find the aforementioned text used or new in either Ebay or Amazon for a decent price. there are several other reinforced concrete textbooks that may be of help to you like Wang and Solomon's wonderful text. It's pretty involved but worth every penny buying it!
You can specify any compressive strength you want as long as you can afford it or it's feasible for the ready-mix company to batch it.
Ummm are you sure you're up to analyzing and designing this structure, especially since it appears to me that you're a little unsure about the dome design?
um mm Natgun is not a construction method. Natgun is a constructor of precast prestressed concrete water storage tanks. i believe they're either based in Boston MA or up in NH.
s
03/21/2010 12:43 PM
Good morning CaptMoosie.
Gotta keep you thinking. That's what CR4 is for, right? <g>
You mean a couple of 1/4" bolts and a clamp? I would think even with the degradation due to phase transformation, welding would be the better way to go.
You were fortunate to have known Mr. Spiegel. I love my RCD book.
Thx for the book referals.
I expect the owners to specify the type of dome design.
03/21/2010 12:00 PM
You may be aware of this structure here in Mesa, AZ. at Val Vista and Brown.
Monolithic Domes Attract Newcomers At Living Word Bible Church ...
03/21/2010 12:47 PM
Good morning lynlynch. Thx for the link.
Good Answers: 179
03/21/2010 1:35 PM
Hello Flyinghigh,
You're very welcome. Glad that I have been able to help is some small manner.
Yes, I have been fortunate to have known Doc Spiegal. He was tremendous educator and very dedicated to the Civil Engineering discipline. When I was attending HVCC I got a very lucky break working for a small Albany NY consulting firm where one of the Principals also taught nighttime structural engineering courses. Of course Doc Spiegal was the CET Dept. Chair and would visit our office from time to time to discuss course stuff etc with my boss. Usually I'd be there at the office in the afternoon after school working.....and sometimes Doc and my boss would invite me into their talks about engineering in general. Man, I felt like I had the Tiger by the tail just being acknowledged at all!!!! *LOL* I was also fortunate to have Prof. Limbrunner for a couple of structural engineering course. Wow, was he ever an educator as well.....ex-US Navy SEABEE and a PE. He was also our ASCE Student Chapter Advise and help us in building a concrete racing canoe. Oh the stories I could tell you about our adventures going to several of the races and the camp-outs throughout the weekend.....lots of great eats and too much booze, which he surprisingly tolerated (well up to a point that is)! *LMAO*
If I am able to find a few more of my reinforced concrete textbooks that deal with concrete arches and domes (many at just boxed away for sake of room in the office), then I'll be getting in touch with you about the titles, authors and publishers. Also, somewhere in my archives here I have concrete design software on a DVD/CD that deals specifically with concrete dome design. I forget the exact title of it...as I have never had the opportunity to use it. Let's see if I can find it, okay?
Are you a pilot by chance? One of these days I would love to obtain my Private Pilot's License. It's been a dream of mine since I was a little kid. Well, maybe someday soon!
03/22/2010 9:00 AM
You were lucky indeed. Experience like that for a young man is incomparable.
I hope you don't go to too much trouble, but if you happen to find some of the research material that would be great.
Yes, I am. I'm a late bloomer, only getting my certificate in 1990. You should go for it. I think a technological background is important. If my significant other ever agrees to fly back to her erstwhile home in New London, CT, I'll look you up.
Good Answers: 179
03/24/2010 9:55 AM
Good Morning Flyinghigh,
Thanks for the complements! I try to endeavor as much as I can. I'm not as young as you think I am as I'll be turning 52 in June.
I do have my New York State Professional Engineer's License and Registration. I'm a late bloomer as well because of the US Army and Reserves, family, house, and advanced engineering studies/degrees (MS/MS Carnegie Mellon U.).....received it '95 some 13 years after receiving my double BS in Environmental/Structural Engineering in '83. The Army paid for much of it thank God since I was a Grenada Vet (2nd Btn./75th Reg. Rangers: Op Urgent Fury) and in the USAR. Resigned my Officer's Commission (Cpt., on Promotion List for Major) in late '91 after returning from the Gulf after DS/DS at X-wife's (aka Tex-Rex) insistance......after 14 total years served, and 6 to go for retirement, but she didn't want to hear about it, period. By now i could have made Full Bird Colonel If I had stuck with it serving in an Engineering Battalion, followed by stint with 98th Inf. Div. HQ in Rochester, NY. Oh well, them's the breaks......
Yes, if you're ever back to New London CT look me up! The drive isn't that bad from here......even Danbury CT is a 1-hour drive from here down the Taconic State Parkway, and then take I-84 East from Fishkill NY (major IBM territory there). We could meet somewhere mid-way for a nice lunch, eh????
Just curious, but you appear to be a CE???
I bet a private pilot too, given the moniker?
03/25/2010 8:32 AM
You have an impressive resume. Too bad you weren't able to stay in the military, but we all have regrets.
Yes, if I ever get back there, I will certainly give you a call. That would be great to meet you.
By education, I have a BSME; but I have drifted into construction design, with an emphasis on structural aspects.
Good Answers: 179
03/25/2010 11:53 AM
Good Afternoon flyinghigh,
Yes, let's get together and have lunch or dinner together when you're able to get beck this way. I hope you can bring your wife along too, and we can make it a foursome. First round of cocktails are on moi. That would be a nice!
That certainly is a change in venue for you from Mechanical to Structural. Not too many make that change. Interesting......
Where in AZ are you located? Mighty nice countryside out there, especially up north near the GC. If it wasn't so blasted hot out there in the summer I'd probably move to some location there or up in northern NM in the high country....just lovely country and totally different than upstate NY. Maybe when I retire eventually.....*LOL*
03/26/2010 10:10 AM
Yes, I will bring Dini when I come; but I don't know when that'll be.
Necessity is the mother of invention.
I am in the northern mile-high country, Prescott area. I can no longer take the summer heat of Phoenix and the southern area. My projects have been scattered thru out the state. Tell me again, your location in NY? The local housing market pricing is very attractive to purchase!
Good Answers: 179
03/26/2010 2:56 PM
Good Afternoon Flyinghigh,
Yes, by all means bring your wife and I'll bring mine, even if she's bleary eyed from working the Graveyard shift at work (she's a RN).
Okay, now I know where you're at! The Prescott area is very nice and COOLER!! *LOL* Good to know that the housing prices are affordable there when it comes time to retire (if ever). The Great Recession must have plummeted the real estate market in your area quite a bit, much like Phoenix, LV, and LA?
I'm located about 25 miles north of Poughkeepsie NY, along the eastern shore of the Hudson River. We actually live about 1 nm from the historic Rhinebeck Aerodrome, which is pretty kewl. As an avid aviation nut-case, I can get my daily jollies watching the old WWI fighters and bombers, as well as the Barnstormers, flying overhead. Now if they could only expand and start including WWII Warbirds, then my year would be made for sure! I was a longtime (21 years) and very active member of the now defunct National Warplane Museum that was originally located in Geneseo NY, south of Rochester. They moved to the Elmira area in the early 90's which killed off a very large and dedicated volunteer base following them southward, which coupled with 3 successive rotten turnouts at their Annual Wings of Eagle airshows due to very bad weather eventually killed the museum. It is too bad that it happened, but the Trustees were blind deaf and dumb about the objections to the museum moving.....even oblivious to a large majority of the membership voting against the move! Go figure, eh? I guess money talks (and the Trustees, many of them were loaded) .....having been a longtime member of the Airshow Planning Committee I got t meet some very distinguished visitors and Airshow Grand Marshall's over the years: Gen. Jimmy Doolittle, Former NASA Astronaut Frank Borman, Ret. BG Chuck Yeager, Ret. Cmdr, Randy Cunningham, amongst others including a whole lot of WWII/ Korea / Viet Nam pilots where some where actual fighter Aces. We even had USAF modern fighter aircraft on static display in our museum collection that augmented our WWII and Korean War A/C: F-15A, F-14D, A-4F and an A-10A for starters. Was a pretty neat museum w/ membership from around the world. Miss it!
03/27/2010 12:30 PM
Good morning CaptMoosie. RN's are great people.
Yes, the economy in the area is extremely slow. If this keeps up, I'll have to find a 2nd job for Dini. <g>
That sounds like a beautiful area of the world you live in. I would like to visit there some day. Kingston airport would probably be the best choice.
Too bad about your National Warplane Museum moving and going belly-up. Reminds me of the old saying, a camel is a horse designed by a committee.
I know what you mean about meeting aviation celebrities. One year at the Airventure in Oshkosh, I sat by and met John Miller, who I believe was from NY. He recently passed away at age 102, but he flew his Bonanza until he was 100. He's my hero.
Good Answers: 179
03/27/2010 3:09 PM
Yes, your assessment that RN's are good people is correct. My mom was one too...actually she still is at age 75 since she never retired her license ans till keeps active at the hospital with the nurse's auxiliary she belongs too. Although my X was a OTR, her family consists of 4 nurses (her mom, 2 sisters and a brother), doctor (brother) and a PA (sister). Then on my current wifes side a shrink (PhD) and psychologist (MS?). My late father was a Dentist. So I'm surrounded by all of these medical peeps!!!! *HELP!!! LOL*
Now now, did you ask Dini if she wanted a 2nd job??? **GRINZ** that's too bad the economy tanked where you are. Around here the real estate market didn't get hit nearly as hard as elsewhere....the values only went down roughly 10-15%, depending on where you're at. They are slowly climbing back upwards little by little unless we hit another burp in the economy highway.
The airport you call Kingston Airport is actually the Ulster County Airport and sits at the western end of the Kingston-Rhinecliff / George Clinton Bridge run by the NYS Bridge Authority. The Village of
Red Hook where I'm at is basically 7 miles road march from the eastern end of the bridge. That airport would be the easiest and best place to land when and if you get back here f you're flying a small private plane....a tad tricky with the approaches, but not too bad. We could pick you up at the airport...it's fairly small and easy to get into and out of. Alternate put-downs are the Dutchess County Airport just south of the City of Poughkeepsie, and some 30 miles south of us. Then there is the Stewart International Airport now run by the Port Authority of NYC. It's also a NYANG base for C-5B Galaxy transports...that airport is slightly more than an hours drive south of here.
I've heard of John Miller before, but never had the honor of meeting him. That's quite the accomplishment piloting an airplane at age 100! I'm surprised that the FAA didn't yank his license years before, but I guess if he keeps on passing the physicals than it must have been okay (like Bob Hoover's adventures with the FAA).
I've never have gotten out to Oshkosh for the air show and convention. It's been a dream of mine to go. I was planning on going with my father for the 2,000 show, but he got sick and passed away in early 1999. Well someday I'll get out there even if it kills me! Problems is where does one stay during the airshow....rather have a motel room (even if it's in Milwaukee) then sleep in a tent for the entire week.....I hope showers are available for the tenter's.
Well, gotta go for now and get back to importing a surveyor's plan (a real mess)...
03/28/2010 10:09 AM
I can't help but wonder what your medical peeps think of the new healthcare law. The Dr. salaries are supposed to be clipped 21%. Its supposed to cover 35 million more people. I figure the Drs needed will come from turd world countries.
Our local economy was fed in part by thousands of Ca. expatriots who were escaping the devastating taxes, crime, and environmental restrictions. Most of that has apparantly dried up tho.
My research of the Red Hook airport says it has a lot of pot holes in the runway, gravel taxiways, and prior permission required (PPR). I consequently figured Ulster (20N) would be the next closest to you. After your reference to Dutchess County apt (POU), I see the Missed Approach Point (MAP) is 1351' above the runway at 20N, while the ILS at POU has a MAP of 313', making it the better choice of the two. Stewart Int'l (SWF), has an even lower MAP of 200'. Its currently reporting 2300 broken, and 10,000' broken. Thx for your note.
At age 96, John Miller's family made him sell his Baron. He was quite miffed, as this left him only his Bonanza to fly! John's lisence was signed by Orville Wright. John at one time was a test pilot for those big amphibious singles that had a major huge pontoon built into the shape of the fuselage, with two outriggers. I forget the name, but I think it was built by a NY company, maybe Republic.
I've flown into Airventure at Oshkosh twice. The first time, we parked wherever the flow of airplanes took us, and stayed in a camper-trailer in the heart of the trailer camping village. Because of the constant arrivals of party animals arriving in the wee hours of the night, and the garbage trucks starting their work at daybreak, I never got a good night's sleep.
The second time we flew in formation with 185 other Bonanzas to park with them and lived in a tent. Showers and a place to plug in your razor was only about 100 yards away. You could stand up in the center of the tent, but you had to duck to enter and exit. My broken back could not stand up to that. It rained and flooded the tent with 4 inches of water on the last night before we left. The only way I'd go again is to stay in a house off airport, but within eyesight of the B2OSH group. Others stay in Fond du Luc or Greenbay.
Do you have a big scanner to import the survey map, or do you just plug in an external hard drive? A local surveyor did a house lot with maybe 5 points for the lot, and 4 for the house, and the invoice was $450. Seems reasonable. How does that compare with your area?
Good Answers: 74
03/21/2010 4:15 PM
You might want to get a copy of "Theory of Plates and Shells" by Timoshenko and Woinowsky-Krieger. The subject of symmetrically loaded shells having a surface of revolution is addressed in Chapter 16.
"Theory of Elastic Stability" by Timoshenko and Gere examines the buckling of spherical shells, as does "Stresses in Shells" by Wilhelm Flugge.
These books are out of print now, but you can pick up a copy through the internet.
You can Google "buckling of domes" and come up with quite a bit of information, including a spread sheet for calculating the buckling load of a concrete dome (I don't know how good it is).
Bruce
Good Answers: 179
03/21/2010 8:03 PM
ba/ael's answer rates a big GA from me!
Well going!!! APPLAUSE!!!!!
I didn't even know that some of these textbooks were even out there....am famliar w/ Timoshenko's text's for the most part, except the two that you named here!
03/22/2010 9:21 AM
Good morning ba/el.
Thx for your input. I have ordered the texts you suggested, along with the others from CaptMoosie.
03/24/2010 1:27 AM
A good book on the subject is Thin Shell Concrete Structures by David P. Billington.
kdelta
03/24/2010 9:18 AM
Good morning kdelta. Thx for the reference.
Good Answers: 74
03/24/2010 11:14 AM
flyinghigh,
I designed a couple of cylindrical water reservoirs with domed roof in the City of Edmonton over fifty years ago. Everything worked pretty well and the tanks are still standing today.
I designed a similar reservoir in the Town of Vegreville a few years later which resulted in a horrible accident during construction. The concrete was being placed from the periphery toward the center when the falsework collapsed, killing one worker and seriously injuring two others.
The engineers retained to investigate the collapse determined that there were not enough posts supporting the roof, so the spacing of posts was reduced by a factor of two, both circumferentially and radially. This resulted in a massive amount of timber inside the walls of the reservoir.
The reservoir was reconstructed with this recommendation and everything worked out okay, but I believe the real reason for the collapse was missed and was not corrected the second time.
When I examined the collapsed falsework, it seemed clear that the vertical posts which had been placed on circumferential lines at eight foot centers, collapsed in a torsional or screw failure. All of the posts buckled in a direction perpendicular to the radius of the tank at the location of the post.
Radial bracing and horizontal bracing between posts on circumferential lines had been provided. At first glance, it seemed like adequate bracing, but it was not! What was missing in the original falsework was diagonal bracing placed between posts on each circle of posts to prevent torsional rotation about a vertical axis.
Don't accept "We've done it this way a million times before". You must insist that the Contractor braces his falsework properly. This includes adequate bracing, both radially and circumferentially.
Bruce
03/25/2010 8:50 AM
Good morning Bruce. I am thankful you shared your experience.
I presume the domed cylindrical tanks in Edmonton were of the reinforced concrete design? Did you use formulas for a domed or conical thin shell? Did they utilize posts thru out the interior, or no posts between the walls? What were their dimensions?
The design of the monolithic domes I am considering is quite different from the one in Vegreville, in that there will be no posts in mine. Google Monolithic Domes to see details. I am a true believer in bracing. My designs tend to be on the conservative side.
As a result of the collapse, were you sued, or did you have engineer's insurance; or how did that turn out?
Good Answers: 74
03/25/2010 10:13 AM
Both reservoirs in Edmonton and the one in Vegreville were spherical domes. The domes had no support other than the cylindrical concrete walls which also served to retain water. The diameter was 200' in the Edmonton domes, a bit less in Vegreville.
The posts I mentioned were temporary. They were used to support the plywood form and wet concrete, then removed when the concrete had cured.
The collapse was a result of contractor's error. The engineering company I worked for was not sued as it was not responsible for falsework design. There was a coroner's inquest which recommended a number of changes in the way falsework should be designed, inspected and constructed.
Bruce
Register to Reply 31 comments
ba/ael (3); bwire (1); CaptMoosie (8); CR4radarriau (1); flyinghigh (14); kdelta (1); lyn (3)
You might be interested in: Rebar, Flaw Detectors
