Previous in Forum: Venture Clad Insulation Covering   Next in Forum: tank weight calculation
HP Heaters and Steam Power Plants
03/19/2010 11:08 AM
i want to know what are hp heaters what is the main function of hp heaters and how they are connected to the steam power plant
Re: HP Heaters and Steam Power Plants
03/20/2010 11:12 AM
http://canteach.candu.org/library/20044213.pdf
Basically for feedwater heating, normally takes steam from initial stages of a turbine. One thing that might be of interest is you can estimate the amount of energy available by looking at the non return valves associated with the particular heater, if it has two non returns in series there is a sufficient amount of power involved to cause a destructive overspeed condition
If you fail to follow through, you will fail.
03/21/2010 3:43 AM
In Steam power plants High pressure Heaters are used to heat feed water. A portion of steam called bleed steam, that extracted from turbine is used in High Pressure Heaters to Heat feed water, latent heat of this bleed steam is utilized otherwise it will lost in condenser with cooling water. Hence over all cycle efficiency of the plant increased. In power plants HP Heaters are connected in feed water line (Line between Boiler feed Pump and Economizer).
