Previous in Forum: Muriatic Acid   Next in Forum: Keep It Simple: Measuring Methanol Concentration in Salty Water
Steel Equivalent
03/19/2010 4:20 PM
Where can I find specifications for material with the following callout from Germany. "Kesselblech (Boiler Plate), P 265 GH, Rm min 480N/mm²"
I am looking for a steel equiavelent I can purchase in th US.
Re: Steel Equivalent
03/19/2010 8:29 PM
The "equivalent" of that steel in the US is
SA/A 516-60
http://www.oakleysteel.co.uk/astm_a_516_plate.htm
Good Answers: 243
03/19/2010 9:51 PM
Good answer Guest. I book marked your link.
milo
04/23/2010 1:51 PM
Due to avaliability, my supplier is reccomending using grade 70 in place of grade 60, what are the differences, what the risks I take?
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
04/24/2010 11:24 PM
Unless a more refined engineering calculations say the contrary, There's should be no problems in using grade 70 instead grade 60. The main difference are the tensile strength (70 ksi vs 60 ksi). Both are pressure plate grades and weldable. I don´t see any big problem.
Kind regards
03/20/2010 1:15 AM
• Good answerers, but I'd like to add that the term equivalent not necessarily means identical.
• The carbon steel material ASME_SA_516 Grade 65 & 70 are plates used in widely range for design and fabrication of pressure vessels, heat exchangers, columns, and equipment used in oil & gas field for moderate-and lower-temperature service.
Good Answers: 25
03/21/2010 3:04 PM
Hi friends,
Just one point: P 265 GH is a pressure vessel plate designation according to EN 10028-2 European standard. Furthermore to the Abdel comment that "equivalent" doesn't mean "identical", just they can be used for the same purpose, there is a difference between European standards and ASME/ASTM ones. The first (in this case at least) steel standard requires notch impact test, while ASTM doesn't and ASME requires according to the design requirements (Section....)
Kind regards
Register to Reply 6 comments
Abdel Halim Galala (1); Anonymous Poster (1); ewatfas (1); Kwetz (2); Milo (1)
