Previous in Forum: Steel Equivalent   Next in Forum: specs for Semperit synthetic rubber seal for valves
Keep It Simple: Measuring Methanol Concentration in Salty Water
03/19/2010 4:28 PM
Does anyone know of a simple/cheap way to measure the concentration of methanol in salty water?
If my memory works back 30 years ...We used the refractive index at Northeastern University to measure MeOH concentrations in water... but I fear the high TDS concentration will throw off this index.
We want to measure methanol in the range of 5% to 80%. Something we can use in the field, or at a pilot plant would be nice.
Any ideas?
Many thanks,
Rock
Re: Keep It Simple: Measuring Methanol Concentration in Salty Water
03/19/2010 7:23 PM
After performing numerous in depth tests during a rigorous session last night I can tell you that you cannot determine the concentration of ethanol in salty water by taste. Decided to pass on the methanol.
[PDF]
PRECISION LASER-BASED CONCENTRATION AND REFRACTIVE INDEX ...
Good Answers: 146
03/19/2010 8:56 PM
Here's a case where a portable Raman would be handy, sample the liquid through glass. All you'd have to do, take a series of samples in which you alter the concentration of methanol from 5 to 80%. Put it in the library and use the Raman for your tests. That's assuming that the TDS factor is fairly constant. You can subtract the methanol profile and get a TDS fingerprint if you want, so you can monitor that as well if it varies.
The intial cost is anywhere from 10 grand afaik for a bare bones model but of course, it depends how many tests you have to do, whether that's cheap or not in the long run.
incus opella
03/20/2010 1:17 AM
IF the salt content and TDS are essentially constant so only the methanol changes, then the boiling point (corrected for atmospheric pressure) could be used. As I recall, the methanol has a much greater effect on BP than dissolved solids, so it might even work in the case of changing TDS, depending on the precision required.
03/22/2010 9:24 AM
Density should be an easy way to estimate the methanol concentration.
04/18/2010 2:14 AM
In a pilot plant situation, you could use a titration. It is pretty straightforward once you get the hang of it. I have done thousands of very similar titrations to measure the surface area of activated carbon as iodine number.
You could adapt the ethanol titration shown in this site to do methanol, noting that you don't need to suspend the sample as they have had to.
http://www.outreach.canterbury.ac.nz/chemistry/ethanol.shtml
artsmith (1); dkwarner (1); lyn (1); morrie (1); Rheolog (1)
You might be interested in: Fuel Cells, Titration Instruments, Spectrometers
