Previous in Forum: 1997 Ford Explorer - No Power When Engine is Cold   Next in Forum: 2001 Chevy Cavalier - Starting Problem
parking brake for actros
03/20/2010 3:37 PM
iam facing aproblem with my actros mercedes truck , after parking for a while i tried to move the vehicle , the vehicle is not moving even after diengaging the parking brake , i checked the is parking brake system everything seamed to be ok ,air pressur was ok inlet and outlet pressure . i dunt know what could be the problem any body can help ?
Good Answers: 97
Re: parking brake for actros
03/21/2010 12:10 AM
How long is a while and what weather conditions were during the while it was parked?
03/21/2010 12:16 AM
Right! Rust!
03/21/2010 8:32 AM
I am no expert, but lorry brake systems are sensitive to any leaks as well as rusting....if it happened quickly (overnight?) I tend to think it was a leak......
If it was some weeks or longer, then rust....
My best guess....
You need expert help.....brakes are not for the amateur....
03/22/2010 3:48 PM
Try and visit your nearest mercedez dealership or repair shop. They will have facilities to read your truck's ECU and pin point the problem. Actros has a lot of microprocessor controls/electronics and I would recommend you don't do any guess work. The earlier Axor models were much simpler to maintain and most problems could be solved by road side shops, but not Actros.
Register to Reply 4 comments
Andy Germany (1); bwire (1); dkwarner (1); QSK (1)
