Previous in Forum: Design Standards for Chemical Reactors   Next in Forum: Rating of Flanges and Valves
8 comments
Shaft and Hole Dimensions
03/21/2010 3:32 AM
Please tell me how to decide dimension of shaft for a given dimension of slip bearing?
Good Answers: 27
Re: Dimension of shaft and hole
03/21/2010 4:18 AM
By "slip" bearing I assume that you mean "sleeve" or "journal" bearing. In my early days the rule of thumb was a thou per inch of the shaft diameter with a minimum of 4 thou. (1 thou = 0.001") Above about 6" this reduces otherwise clearances can get too big.
Having said that, there is no substitute for the equipment manufacturer's clearances, as he knows the specific bearing loads, speeds, lubricating oil type and quantities etc of his equipment
I have no special talent. I am only passionately curious. Albert E
03/22/2010 9:44 AM
Thanks for Answer
03/21/2010 4:32 AM
you can check this on a more complete bearing catalogueof your bearing
03/21/2010 8:11 PM
Gives pretty much the same answer as #1 except that it goes down below 0.004. My copy is over 40 years old, so things may have changed a bit.
Good Answers: 97
Re: Shaft and Hole Dimensions
03/22/2010 3:28 AM
More information please:
Bearing type and material, diameter and width of journal, lubrication type and method, application...
03/22/2010 12:46 PM
hi, the dimension of hole and shaft are based on your work together. you need check tables of tolerance dimensions based on ANSI norm.
in the SKF web you can find this tolerances for the hole, this are based on the dimension of your bearing.
first find the bearing to you use (if are not SKF only found the same dimension and type), and found the dimension sheet of the bearing and thats have a data about the tolerance of the hole for montage and the shaft.
03/22/2010 9:11 PM
You are talking about the wrong type of bearing I think.
03/24/2010 8:37 PM
A crankshaft bearing on automobile gasoline engine is usually .0015" to .002" for the main bearings, and .0025" t0 .003" for connecting rods.The crankshaft journal diameter is usually 1.75: to 2.00".
Maybe this will help as an example.
Register to Reply 8 comments
Anonymous Poster (4); bwire (1); Hari Ram Narvariya (1); Kaisan (1); olmos909 (1)
You might be interested in: Slip Rings, Line-shaft Spools
