Previous in Forum: Wide-Angle LED Drivers   Next in Forum: LG Plasma TV / Sky HD Compatability Problem
Blu-Ray DVDs and Anamorphic Format
03/21/2010 10:58 AM
What is the relationship, if any, between Blu-ray DVDs and the anamorphic format? Are all Blu-ray discs natively anamorphic, or does that even make sense?
I've seen a few Blu-rays labeled anamorphic, but that could just be hype, like saying "this new car is equipped with an engine".
Pathfinder Tags: anamorphic bluray DTV HDTV widescreen
United States - Member - Member in Good Standing
Good Answers: 61
Re: Blu-ray and anamorphic
03/21/2010 1:14 PM
First off, a Blu-Ray disc is not a DVD, any more than a DVD is a CD. About the only thing they share is physical dimensions. Where CDs use an infra-red laser to read and record and DVDs use a red laser, Blu-Ray uses a blue-violet laser, which allows for a much smaller data spot on the disc and allows for vastly more data on a single disc.
As for anamorphic formatting, that refers to a photographic technique that compresses a widescreen image onto a standard 35mm theatrical film without letter box bars using a special lens, thus allowing somewhat better resolution by using more of the frame. When projected in a theater, a special projection lens is then used to decompress the image back to the theatrical widescreen format.
Anamorphic widescreen on the other hand is a digital compression technique which compresses a widescreen image into a standard 4:3 DVD frame, and which requires the proper codec to decompress the image.
It is worth pointing out that when the DVD was being developed, the 4:3 aspect ratio was still the standard for television and computer displays, and widescreen was primarily for theatrical use. Thus, the video resolution of DVD images is 760x576 (4:3) and special techniques are needed to adapt to 16:10 and 16:9 formats.
Since then, widescreen has come into widespread use and 4:3 is slowly disappearing. While I have been unable to find any specific information concerning the actual encoding of video format data, the maximum video resolution of Blu-Ray is 1920x1080, which is 16:9. This would seem to indicate that the native format is widescreen. It is worth noting that Blu-Ray discs use mpeg2 and mpeg4 codecs, whereas DVDs use mpeg1 and 2.
I suppose it's possible that a Blu-Ray disc might use a sort of reverse anamorphic compression to compress a 4:3 image into a 16:9 format, though I admit I don't really see the point.
DrMoose
Good Answers: 96
03/21/2010 10:46 PM
Spot on, Sir ... nicely said. Kind regards .....
"Just when I had all the answers, they changed all the questions"
03/22/2010 1:35 AM
It's also worth mentioning that screening an anamorphic 35mm film print with the proper equipment results in an image aspect ratio of roughly 2.35:1. Much wider than the 16:9 ratio screen currently available in our modern HDTVs.
Does the anamorphic term in Blu-Ray marketing imply that one of the viewing modes available on that disc allow the program to be seen in the original 2.35:1 aspect ratio if the original cinematography was composed in that aspect ratio?
This would mean of course that one would see thick black bars masking the top and bottom of the HDTV screen but the composition of the frame would be what the director and cinematographer intended for theatrical anamorphic viewing.
Good Answers: 97
03/22/2010 3:50 AM
Yes often this is the case though if a standard is available I'm am not aware.
anamorphic = ambiguation of typical widescreen format
Register to Reply 4 comments
bwire (1); DCaD (1); DrMoose (1); intalekshul (1)
