Previous in Forum: Pressure Loss Through Pipe Size Reduction   Next in Forum: Exemption Pressure
Escalator Damage by Water
03/22/2010 1:24 AM
Is it true that upon water contact to the handrail of the escalator will render the handrail stuck and caused damage to the handrail drive rollers and pressure rollers? I tried to look for article write-up for damage assessment for escalator but none were available.
Seeking help here and thank you in advance for kind contributions.
Re: Escalator Damage by Water
03/22/2010 1:38 AM
It seems more likely that the water might come between the handrail and the rollers, which would cause the handrail to stall until everything dried out. But damage to the rollers?? There might be a bit of rust that could be wire-brushed out; some disassembly required. The water might also make the handrail stick to its sliding support, but again drying it out ought to fix that, too.
Good Answers: 38
03/22/2010 8:15 AM
I've seen several times where the handrail sticks to the slide rail and the drive roller and handrail start rubbing and usually causing wear on each other. Anytime water gets between a slider bed for a conveyor or handrail and slider the aforementioned locks up like honey on a playground slide. The less contact between the rail and slider the better. Outdoor rails sometimes have a thin ridge to allow for easier movement, but pressing down on it will cause it to stall. Once it dries it's good to go.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Good Answers: 141
03/23/2010 3:48 AM
Escalators can function outside in the rain. There are many here in Florida. The hand rail seems to function without problem, even better since water between metal and rubber is used as lubricant. Some type "wet" bearing boat shaft use this principle too. When your escalator has been under water (submerged) we need a different approach.
Plenty of room here
Register to Reply 3 comments
charsley99 (1); dvmdsc (1); Tornado (1)
