Previous in Forum: Laptop Security   Next in Forum: ANSYS and Thermal Analysis
Simulink Modeling of Wind Energy System
03/22/2010 1:32 AM
In MATLAB 7.6.0 , I made use of a single dimensional look up table to input a series of wind speed data to the "Wind speed" input in the 'Wind turbine' block.
However, it shows an error saying there may be a 'singularity in the solution'.
I want to know if the approach I've adopted is right and what input should be used to the block or what modifications should be made to rectify this problem.
The smallest deed is greater than the grandest intention.
Re: Simulink modeling of wind energy system
03/22/2010 4:02 AM
That might be better than a "duality in the solution." If a cell referenced in your formula refers to something outside the boundary of the table, this might be a case of division by zero. (?)
Watch out for any singularity! If it inflates into a new universe, it might swallow up this one. Oops.
03/26/2010 1:51 AM
Well,I used a single dimensional look up table having a series of wind speeds and I input it to a wind turbine blockset.
Now what do I have to make changes to ? should I include a Saturation block after the table,perhaps?
Need some modeling suggestions! :(
03/26/2010 1:55 PM
I am not familiar with the structure of MatLab, so I was going only on how an MS-Excel lookup table works. In that case, if you somehow try to look up a value outside the defined range of the table, you might well have a calculation that includes a division by zero. MS-Excel would give the message DIV0! (or something like that); I'm just guessing that "singularity" means the same. And then I made two jokes.... My apologies for any confusion; I was just having a bit of fun.
Re: Simulink Modeling of Wind Energy System
03/30/2010 9:45 AM
yes. my e-mail is tpmniki@gmail.com, I will be more glad if you will show the look up sketch. let me try. your error lies on the in put. Ok. try revolutions of the propellers as input, Hence, angular acceleration as input.
04/01/2010 5:58 AM
Tornado,thanks so much. I got a better idea about the problem now! Time to break my head,I guess! And it was a good one,by the way! :)
tpmniki,I shall mail you the file ASAP! Thanks so much!
06/04/2010 7:02 AM
Hello friends
I am quite new to matlab Simulink, I have started designing of Grid integration of wind turbine
I have used 1. Wind turbine block (have input of speed,pitch angle, generator speed & torque as o/p)
2.the torque is used as input to drive the asynchronous block(squirrel cage, in pu)
3. which consist of two step up/step down t/f
4. 30 km PI section Transmission line ,
5. I considered grid as programmable voltage source
so i have one fundamental question how the parameters for all the components are set ?
based on what manner the parameters should be calculated?
Just dont reply like read basic machines book blah blah blah...
just reply with concrete method from where i have to start calculate the parameters?
if there any pdf or books for this help me out.
If there is any other open source package to do this simulation just let me know?
Register to Reply 6 comments
Anonymous Poster (1); saarang (2); Tornado (2); tpmniki (1)
