Previous in Forum: Heat Treatment Processes   Next in Forum: Painting for DM Water Service
SS 304 magnet or not?
03/23/2010 2:19 AM
Hello,
I need to know SS304 will be have magnetic property or not?
SS304 is Austenite SS.and FCC structure.
So if any heat treatment is done like Annealing(1050-1100) and Quenching(Air spray) on SS304 it will have magnetic property or not. Carbon is 0.07%max,Ni is 8-10.5%,Cr is 17.5-19.5%, Hardness 82.8HRB.
Re: SS 304 magnet or not?
03/23/2010 4:18 AM
03/23/2010 5:10 AM
All austenitic grades have very low magnetic permeabilities and hence show almost no response to a magnet when in the annealed condition; the situation is, however, far less clear when these steels have been cold worked by wire drawing, rolling or even centreless grinding, shot blasting or heavy polishing. After substantial cold working Grade 304 may exhibit quite strong response to a magnet, whereas Grades 310 and 316 will in most instances still be almost totally non-responsive.
03/24/2010 12:08 AM
Hello ,
It means that SS304 after machining to 20 mm thick plate may show magnetic property.?
what was the technical reason that SS304 after cold work will have magnetic permeability more.?
After cold work Austenite (FCC structure) turns to BCT or BCC?
Good Answers: 143
03/24/2010 7:04 AM
Deformation-induced martensite.
Good Answers: 143
03/23/2010 7:02 AM
This is a simple question to answer. Get a big magnet - the kind that rips your fingers off when you hold it near a chunk of iron - and touch it to a piece of 304. Then touch it to a 304 screw. Repeat as many times as you need to get the idea.
Anonymous Poster (1); lyn (1); rahoofhassan (1); TVP45 (2)
