Previous in Forum: Hydrogen Storage - What's best?   Next in Forum: Laser Light Show
High Pressure Vented Ball Valves
02/06/2007 10:20 AM
which side does the vent side of a high pressure vented ball valve go? Upstream of Downstream?
Re: High Pressure Vented Ball Valves
02/06/2007 10:26 AM
Please, attach a symbol for your valve. Is it a 3 way? The simple statement that it is a ball valve and vented does not make sense. If it's a shutoff valve, there will be 2 ports, and one is always pressurized, so, no vent at all.
If it's a 3 way (the vent being the 3rd way), it may be oppened to atmosphere, or you may be able to connect it to some line.
Please specify better. I don't think I understood your question fully.
Humm... suspicious you are...
02/06/2007 11:57 PM
The vent goes on downstream side to permit relieving pressure on the downstream piping and equipment.
Upstream pressure, as in a boiler, requires a major shutdown of the whole shebang!
If you had a vent on the high side it could create a problem in and of itself.
02/07/2007 9:44 AM
Yes, and this is actually a 3 way valve, one way venting downstream to atmosphere and upstream closed, and upstream and downstream connected and vent closed to the other position.
02/07/2007 7:39 AM
making hole on upstream side.
bhrescobar (2); Stirling Stan (1); tonic (1)
