Previous in Forum: High Pressure Vented Ball Valves   Next in Forum: 020
14 comments
Popular Science - Weaponology - New Member Hobbies - Musician - New Member
Laser Light Show
02/06/2007 10:53 AM
Hi--
I'm putting together a laser light show (projector). I've got a 245mW DPSS green laser and I'm buying a 200mW 660 nm red laser to combine for (switchable) orange and yellow beams. (I'll have to attenuate the green quite a bit.) The X-Y scanners (galvos) I plan on building myself using small high speed solenoids and first surface >96% mirrors. Do any of you laser experts out there know if this will work well enough, or do I have to spring for the very expensive Cambridge or DT's? I plan on only doing simple graphics: sheet of light, beam-show, no complicated high speed graphics.
Thanks in advance
Steve
Pathfinder Tags: galvo Laser scanner solenoid
Re: Laser Light Show
02/06/2007 2:35 PM
Blimey! do you need such high powered lasers for a light show??
250 mW sounds an awful powerful laser as far as eye exposure is concerned!!
John.
02/06/2007 2:40 PM
Hey John,
Yeah, outside night-time shows usually require 1 Watt or more to be nicely seen without fog, but this'll have to do.. (for now)
(No audience scanning of course)
Steve
02/06/2007 2:47 PM
Oh..... you learn something everyday....
What about aircraft though... I wouldn't like to be a passenger on an aircraft that has a blind pilot at the controls!!!
LOL.... John.
02/06/2007 3:00 PM
The beams aren't aimed up into the sky, they are about 30 degrees up from audience viewing angle and contained within the mountainous terrain of the area. Other areas would have different considerations. They are also modulated very rapidly so as to avoid disturbing any nocturnal wildlife. There is alot of planning and precautions prior to one of these shows.
02/06/2007 11:50 PM
Best you check FAA or other aircraft authority as well as Product Safety Commission for the legal restrictions, requirements, and permits, etc.
02/07/2007 12:32 AM
Hai,
Build your own scanner,which is a good idea!here is some useful resource. http://elm-chan.org/works/vlp/report_e.html
Sure,if you need a scanner with a speed not so high,you also could do some internet search on some low cost scanner as much money and time will be saved. just my tips:-)
Regards
honya
02/07/2007 1:43 AM
Steve,
Be very, very careful with such strong lasers, especially the green one, but preferably reconsider the plans. You can destroy eyes at very large distances (miles?). Check whether it is even legal to use such lasers for light shows/your intended use.
Mike
02/07/2007 10:31 AM
There are regulations for laser shows within crowds. Lasers above a certain power level (that can damage the eye, 5mW?) need to be 3 meters above the crowd. See also RC plane servos for the mirror reflector servos (wireless). Also see this month's IEEE Spectrum Magazine for a interesting article -http://spectrum.ieee.org/feb07/4901 --not sure if you can access the article.
Also, use your old camera telephotos for inexpensive decent optics. Enjoy
02/07/2007 2:00 PM
Guest(s) I think that Steve knows what he is doing and what regulations he has to observe.
At least I hope so :-)
John.
02/08/2007 7:32 AM
Hi All
Yes, I am aware of the dangers involved, the CDRH regulations/ variances and the FAA. I have been working with lasers and shows since 1989 and I still have full vision in both eyes.as well as my audiences. I am not new to the science and hazards of coherent light. Thank you for the concerns, though. Good tips. Thanks. I am familiar with collimating optics; the divergence ratios are <1mrad, so I'm ok from that respect. I hadn't thought of remote control servos, though. Interesting....
07/16/2009 5:55 PM
Steve: I am a Security officer in Rochester, New York and I have to attend the laser light shows on a continual basis. These are green lasers that are beamed across a huge gorge on mirrors and I am somewhat concerned about the safety factor, not only for myself but for the parents and the children. Can I call someone after they provide me with the specs on these units to verify if they have been tested as safe?
Thanks for your reply if you see this. Respectfully, Alan Rampe
alan_rampe@yahoo.com
02/08/2007 7:57 AM
Speaking of hazards and regulations, I wonder if they have a licence for this? http://photonlexicon.com/gallery/Everyone/skycutter40
02/08/2007 11:49 AM
Now I've seen everything.....
A flying lawn mower....????!!!!!!!
02/08/2007 11:52 AM
Yeah..
Somebody's got a lot of time on their hands.
Register to Reply 14 comments
Anonymous Poster (4); Electroman (4); steve-o (5); Stirling Stan (1)
