Previous in Forum: resonance   Next in Forum: Taps on Regulator
Single-Phase PLL
03/25/2010 5:39 AM
Dear All,
Can anybody suggest better way to generate PLL (phase locked loop) for single phase voltage source.
I have PLL for 3 phase.i.e by converting three phase to 2 phase etc..
But for single phase can any body shae some idea on how to impelemt PLL for single phase grid connected inverter.
Rgds
Mukesh
Re: Single Phase PLL
03/25/2010 10:54 AM
Are you trying to make a homemade Grid Tie Inverter system?
Good Answers: 80
Re: Single-Phase PLL
03/26/2010 10:38 AM
It always depends on the response time and precision you are looking for.
If slow is OK, you can filter the AC and use a zero crossing with very little hysteresis to generate a nice square wave used for the phase comparator. Of course, the following filter will be very slow as it will only get valid phase info twice per cycle. It will have some phase jitter.
Good luck
03/26/2010 11:08 AM
Actually am working on single phase active filter and to provide syncrhonisation with grid i need single pha PLL efficent mehtod.
I want to write this PLL in my software only...
Register to Reply 3 comments
Anonymous Poster (1); marcot (1); tcmtech (1)
You might be interested in: Converting Services, Single Phase Transformers
