Previous in Forum: Single-Phase PLL   Next in Forum: regenerative breaking
Taps on Regulator
03/25/2010 8:48 AM
Can somebody help me explaining the funtion of taps on regulator?
what is saturation in tap changer transformer?
what is maximum and minimum bandwidth in transformer?
Re: Taps on Regulator
03/25/2010 8:49 AM
04/02/2010 3:54 AM
Dear Sir,
Normally we expect to get the output voltage in the designed ratio-(like
11000 V / 433 V). This is possible if we get the Input voltage as per the design
parameters which is not possible in reality. There are additional Turns to
compensate for variations in Input Voltage ( + or -) and these are connected to
a switch which can make desired connections to get proper output even the input
varies + or -.This witch is called as Tap Changer and this is the function of the Tap
Changer.
The normal variation for compensation ( Band width) is normally 95 % to
105 % of input voltage in 5 steps the middle tap being for designed (normal) output.
Let some enlighten me on " saturation in tap changer" !!
Manroop, Chennai.
Register to Reply 2 comments
