Previous in Forum: Suffixes for ASME Material Grades   Next in Forum: Disagree with the recycle plastic bottles and bags
10 comments
Gear Through
03/25/2010 9:32 PM
This question is about cycle gas turbo-compressor fault diagnose and i have no idea of what gear through is . Is it a component or part? Thanks
Problem: bearing temperature at gear through is too high
Possible causes:
a. oil temperature is too high
b. bearing damage
c. poor oil quality
d. shaft vibration at gear box too high
I am not a home work cheater. I am a translator seeking professional help
Re: Gear Through
03/25/2010 11:49 PM
It is a typo.
I am not sure what it was supposed to be, but it may be gear pump, maybe gear tooth, might be something else.
Re: Gear Through
03/26/2010 1:05 AM
Gear trough, is the area where lubricating oil resides as the gear passes through it.
Sort of like a sump.
[PDF]
MAINTENANCE MANUAL
Good Answers: 27
Re: Gear Through
03/26/2010 3:59 AM
GA - I think you've got it.
I have no special talent. I am only passionately curious. Albert E
Re: Gear Through
03/26/2010 8:03 AM
Item #23 on the parts list. I suspect that it would have had a different name if it had been "Made in USA".
But, then, hardly anything is "Made in the USA" any more.
Thanks!
Re: Gear Through
03/26/2010 10:44 PM
Good answer Lyn, but it is still a typo as written in the OP..trough vs through..
Re: Gear Through
03/26/2010 10:50 PM
And where is the OP?
Re: Gear Through
03/26/2010 11:03 PM
No worries Lyn, Wingman is always here. But it is the Saturday here in Asia, it may not be till Monday when he gets back.
Re: Gear Through
03/27/2010 10:09 AM
I get a chuckle sometimes reading instructions for some item I've just bought. Nothing comes to mind right now, but it usually looks like it was written in one language, say German, then translated into Chinese, then into English.
My guess is that the translator thought they were correcting a mis-spelling.
Re: Gear Through
03/28/2010 11:04 AM
It seems one of the bearing temperature is high and 'gear through' may trying to indicate location of the bearing. Most probably drive end bearing or gear side bearing.
Re: Gear Through
03/28/2010 11:15 AM
Go here: MAINTENANCE MANUAL
and check pages 3 and 4. Page 3 shows a cut-away identifying gear trough and page 4 shows item #23 as gear trough.
Register to Reply 10 comments
Kaisan (1); lyn (5); Steve S. (3); Vanam (1)
