Previous in Forum: Bolting   Next in Forum: Equilibrium Temperature
number of rolling elements for SKF 6220...
03/28/2010 8:30 AM
Hello everyone
i'd like to know where or how to get the number of rolling elements for the bearing type SKF 6220 to calculate it's frequency since i'm facing a problem of high vibration on motor fitted with this bearing...
Regards
TheBlade85
Re: number of rolling elements for SKF 6220...
03/28/2010 8:56 AM
Go to skf site www.skf.com
There you can find all the relevant details
Got to products (top bar)
Then Left side bar select Rolling bearings -> Calculations.
In the pop-up box select bearing frequencies,
On the top select bearings
Bearing frequencies
Every care has been taken to ensure the accuracy of this calculation but no liability can be accepted for any loss or damage whether direct, indirect or consequential arising out of the use of the calculation.
BearingSelect bearing
select bearing number (6220) - there are a few variants there (5 of them 6220 2RS1 to 6220)
Then you have to feed the RPMs and it will give you all the values.
This facility is available in SKF as well as FAG-INA and I am regularly using it.
