Previous in Forum: USB Drive   Next in Forum: How Small are Tiny Bugging Devices?
8 comments
Datasensor -Italy make photocell sensor
03/28/2010 12:45 PM
Dear all,
I have one photocell which is Datasensor make (Italy).
Datasensor type is TLµ-011.
It has both option PNP and NPN.
But how to select it I dont know.
Is there anybody to guide me.
thoughts becomes things.
Good Answers: 141
Re: Datasensor -Italy make photocell sensor
03/31/2010 11:30 PM
next door? try this Datasensor India Private Limited; Photoelectric Sensors, Miniature ... Datasensor India offers an advanced line of Miniature Photoelectric Sensors, S8 Series, sourced from Datasensor SPA, Italy. ... www.ipfonline.com/companies/.../datasensor_india_private_limited_2
Plenty of room here
04/01/2010 1:17 PM
Thank you,
I got the swith inside the sensor to change from PNP to NPN.
But what is PNP and NPN.
Good Answers: 141
04/01/2010 1:26 PM
That is the type of transistor output connection. These photocells work on DC - mostly in a range from 12 to 24 volts. PNP means the output is delivered from a PNP transistor. NPN is a NPN transistor. These photocells have a cascade output circuit so that you can use or a -12 volts (minus- negative) or a + 12 volts (plus- positive) output to energize your switching device. (relais- coil, lamp or whatever)
Plenty of room here
04/05/2010 2:17 PM
Thank you,
need some more
Good Answers: 141
04/01/2010 1:35 PM
If you have 3 wires or connections: one is for +12 volts, one for -12 volts (ground level) and the third gives the output in + 12 volts or - 12 volts depending on PNP or NPN choice. It should be on the instruction paper.
Plenty of room here
Good Answers: 141
04/01/2010 3:36 PM
check transistors: junctions
Plenty of room here
04/05/2010 10:28 PM
Here's the tech-data file for this sensor.
04/08/2010 1:37 PM
Thank you,
Register to Reply 8 comments
Anonymous Poster (2); dvmdsc (4); sandeep lokhande (2)
