Previous in Forum: I-Beam Calculations   Next in Forum: Face Both Ends to Maintain OAL.
Steam Turbine Vibration
03/29/2010 3:46 PM
We are having 8 mw triveni steam turbine . We are facing in HP Side horizontal vertical raising upto 10mm/sec do have any idea for this problem.
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
Re: Steam Turbine Vibration
03/29/2010 7:27 PM
First of all: Did you check the runouts when the coupling was assembled?
If the above was fine, subsequent coupling slippage could be one of many causes.
Did you experience a system fault? Was the unit sync'ed to the grid properly? Did you have any issues with the couping bolts during the last shutdown?
Best regards, HeviiGuy
03/29/2010 11:28 PM
You could try stopping the thing and counting the blades?
03/30/2010 12:52 AM
Not much to do on. Is the frequency running speed? Could be balance, alignment, rub, instability, wiped bearing, resonance, rotor bow, and many many other things..
03/31/2010 11:08 PM
Dear Guest,
Your data message expressed for the 10MM/Sec. is not clear.
1. The following details to be furnished to analyse the causes of excessive vibrations.
a) turbine allignment details and values.
b) critical speed.
c) variations if any in the steam parameters
d) Some times electrical side also contributes to vibration in excess. In one
case of a similar turbine capacity. the magnetic side of alternator problem
was the main cause of excessive vibration.
cause of vibration
Try to give a brief steps by you to start and load the turbine.
DHAYANANDHDAN.S,
CR4 MEMBER,
INDIA.
Reply Score 1 for Off Topic
Anonymous Poster (1); BoltIntegrity (1); dhayanandhan (1); Steve S. (1)
