Previous in Forum: Fanuc Parts   Next in Forum: Basic Power FET Question
Flash Lamps
03/30/2010 2:21 PM
Hallo colegas:
I had during a time a high tension flash lamp (with a circuit ,who triger it ,one time a second)
The lamp does not have a nummber, only i can say has an ""U form"
I know, like any lamp, they have certain amount of working hs .
I need information over this lamps .
Under what name o links can i go to factory caracteristis ?
Thank you very much .
krasnopolsky
krasnopolsky
Re: Flash Lamps
03/30/2010 5:08 PM
Rayethon might be a place to start. Search GlobalSpec for flash lamps or UV lamps for other manufacturers.
Re: Flash Lamps
03/30/2010 7:13 PM
Thank you
You are great .
Wish you the Best .
krasnopolsky
krasnopolsky
Re: Flash Lamps
03/30/2010 7:19 PM
Thank you again VRBARNET
I will start there.
Krasnopolsky
krasnopolsky
Re: Flash Lamps
03/30/2010 7:37 PM
You are welcome!
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
Re: Flash Lamps
04/01/2010 10:20 AM
It's probably a type of Xenon strobe tube:
Google search
Tom
krasnopolsky (2); tdesmit (1); vrbarnett (2)
You might be interested in: Lamps, High Intensity Discharge Lamps, Heat Lamps
