Previous in Forum: Flash Lamps   Next in Forum: Transmission Line Stiffness
9 comments
Basic Power FET Question
03/30/2010 3:06 PM
I am clobbering together a solenoid driver out of availables and want to double check that I am correctly diagnosing the FET failure causes.....
I'll eschew schematics because I haven't done anything remotely complicated....
Am I right in thinking that when I put a IRF510 as a low-side switch (with nothing else, no diode on the solenoid) for the solenoid (36V, ~4A peak, 2A holding) and drive the gate with 5V the FET failure is MOST LIKELY do to "punch through". (the D-S channel isn't "wide enough", Vgs isn't high enough)
as opposed to dv/dt failure or inductive kickback overvoltage.....
Thanks for your time.
Re: Basic power FET question
03/30/2010 4:36 PM
If you don't provide a current path for when you turn OFF the solenoid, you will be punching through the DS barrier. Many power FETS will permit this for awhile but none will permit this forever. A snubber network of either a capacitor (slow turn OFF), reverse biased diode (fast turn OFF) across the solenoid coil or even a clamping zener diode across the Drain and Source (fast turn OFF) will preserve your FET.
Good Answers: 32
Re: Basic Power FET Question
03/30/2010 10:56 PM
The gate threshold voltage for the IRF510 is listed as 4 Volts so if your 5 Volts is real (not out of a TTL gate or such) then it should be turning on hard enough.
BUT, the Drain to Source breakdown voltage is listed as 100 volts and the back EMF from your solenoid would easily exceed that. I have no doubt that without a reverse diode across the solenoid, the FET will be destroyed when it turns off.
johny451
Good Answers: 12
03/31/2010 12:40 AM
Place a 3/ 6A diode in reverse across solenoid valve or across FET (S & D) will solve your problem. I think when solenoid is switching off the transients are damaging the FET.
Subramanyam
03/31/2010 12:45 AM
So the verdict is inductive kickback... many thanks for your responses.
03/31/2010 1:05 AM
IRF510 gate turnon voltage should not be less than 10 V to fully turn on the FET, if a voltage beetween 4 and 8 volts is applied to the gate the FET will act as a voltage dependant resistor and will not open fully, it will heat up,
When you turn it off, yes it is a inductive kickback and aa Diode across the solenoide is absolutely necessary
Regards
dont say it, write it
Good Answers: 32
03/31/2010 1:14 AM
My mistake. The threshold voltage is that voltage where the drain current is less than 250uA. So 4V is the maximum voltage where turn off can occur.
To turn it on you should have >=10V - I agree.
The reverse diode across the solenoid is still a must.
johny451
03/31/2010 3:03 AM
Also a series blockig diode would not hurt iether.
03/31/2010 9:24 AM
You would be better off if You COBBLE it together then CLOBBER it together. Couldn't resist this
Just teasing
oilcan13
03/31/2010 12:21 PM
I would think a "reverse" protective diode should be a given across an inductive load.
Register to Reply 9 comments
Anonymous Poster (1); Dead Bear (1); garth (1); Johny451 (2); kvsubramanyam (1); Le_Noble (1); oilcan13 (1); redfred (1)
