Previous in Forum: Tinned Ground Conductor   Next in Forum: droop
100A panel feed #1 vs. #3 debate
04/01/2010 6:35 PM
I am feeding a 100A panel nothing fancy just regular. I typically use 60 degree centigrate wire and terminations for sizes #14 through #1 and 75 degree C from 1/0 and up. Somebody told me since a #3 is good for 100A at 75 degree then that can be used in lieu of the #1 which is 110A's at 65 degree c
thoughts?
guest
Good Answers: 141
Re: 100A panel feed #1 vs. #3 debate
04/01/2010 7:58 PM
T have distributor datasheets for cable. I still use the Graybar or McDonald's (RIP)sheets and notice different types of insulation. If I make my choice, I go for the biggest.
I rather see it myself than hear it say from somebody, because when the inspector comes somebody in trouble will be me. This question is like frying eggs in teflon coated pan or not.
Plenty of room here
Good Answers: 804
04/01/2010 8:11 PM
I'll assume that you are in North America and you are referring to AWG ratings in your descriptions.
But where the heck are you getting your information? There is no #3 AWG building wire available commercially, so if you are reading off of a chart from a wire manufacturer it is meaningless. The only thing that counts is the NEC table that pertains to the specific installation requirements you must follow for your situation. Above ground, free air, underground, in raceway, how many conductors with it, voltage drop over distance etc. etc. etc. all contribute to which ampacity table you must use. Get yourself a copy of the NEC and look through the myriad of charts in Article 310.
04/06/2010 3:13 AM
→ British Standard 7671.
Register to Reply 3 comments
dvmdsc (1); JRaef (1); PWSlack (1)
