Hello All;
I have an issue that I'd like to ask about. We have a "new" freon condenser that was recently received as part of a large expansion project. We have major issues on the tubes in the condenser. The condenser is 18" diameter. Tubes are 3/4" diamter x 0.049" wall thickness in C70600 90/10 Cu/Ni finned tubing. The condenser utilizes sea water in the finned tubing and refrigerant R-507 on shell side. We did a baseline eddy current survey on the condenser which revealed anomalies and indications of pitting, adherent foreign material and embedded foreign material. After discovering these issues we had concerns on the service life of the condenser. Decision was made to removed 2 tubes and send out for detailed internal analysis. Results of this revealed internal diameter pits, parrallel ridges oriented at approx 45 degrees to the longitudinal axis of the tube and appreciably less than 0.049" minimum thickness as described in ASTM B 359. Macroscopic analysis also revealed significant surface roughness on interior of tubing. In the opinion of the inspection company that did the analysis the surface roughness will facilitate retention of biological deposits and significantly accelerated corrosion. It is very likely we will retube both of these condensers but I've been asked to develop a risk profile & expectation of remaining life of these tubes. Do any of you have experience or recommendations on how to go about this? I'm somewhat familiar with API RP 579 (Fitness for Service) but have only been aware of using that for evaluation of pressure vessels and tanks. Are any of you aware or familiar with a process industry standard for evalution of remaining life in Cu/Ni tubed condensers in refrigerant service? Thanks in advance. I'll also be inquiry with our on contract inspection company on this as well.
