Previous in Forum: Hole Finishing with Reamer   Next in Forum: Sheet Metal Bending Calculations...help
India - Member - New Member
CNC Machines
04/02/2010 1:15 AM
What is the difference between Vertical machine centre (VMC) and a CNC milling machine?
Pathfinder Tags: CNC CNC machines vmc
Re: CNC Machines
04/02/2010 11:56 AM
CNC is the generic term. A VMC positions the spindle (with the cutting tool) above the table. There are also horizontal mills (HMC), with the table and spindle flopped sideways. Both are "CNC milling machines".
Re: CNC Machines
04/02/2010 10:17 PM
Vertical machine centre (VMC) is a cnc machine with multiple cutting tools which are automatically selected and changed by the machine. and a CNC milling machine has a single tool holder and tool changes are manual.
Re: CNC Machines
04/03/2010 1:44 AM
Wrong, though both descriptions could be right.
Re: CNC Machines
04/03/2010 2:15 AM
That's really intelligent!
Re: CNC Machines
04/03/2010 8:55 AM
The basic differace between C.N.C milling and Machining centre is in Milling M/C there is no tool magzine at all.Ie, if a machine is having tool magzine or automatic tool changing mechanisum,then only we can calll as a machining centre.
Re: CNC Machines
04/07/2010 6:12 AM
ya informative thank you all for the information
with regards
hudson george thomas
Register to Reply 6 comments
Anonymous Poster (1); David bijo (1); hudsthomas (1); lyn (2); pantaz (1)
