Previous in Forum: PWHT Chart   Next in Forum: gd square value for vacuum pump rotors
Calculating Outer Diameter of Pipe
04/02/2010 8:40 AM
Isit possible to calculate the outer diameter of a pipe using the parameters like flowrate, velocity etc.,without calculating the ID of the pipe??.
Since there is an two formulae in ASME B31.1 for calculating the thickness of the pipe using inner diameter and outerdiameter as well.Plz let me know how we calculate the OD of the pipe first!!!!!
Good Answers: 29
Re: Calculating Outer Diameter of Pipe
04/02/2010 9:04 AM
Measure around the pipe. Divide by 3.14. Have a nice day.
Good Answers: 16
04/02/2010 9:49 AM
In MOST CASES its the inner diameter that is the more important and should be calculated rather than worrying with the outer diameter anyway so whats the point???
The ID is always going to vary depending on the wall thickness of the pipe being used...
04/02/2010 11:47 AM
One does not really calculate the O.D.; Pressure and flow calculations depend on the I.D. instead. Once those calcs are done, you select from a table of standard pipe sizes one that has sufficient thickness to withstand the pressure, and I.D. equal to or greater than the prior calc.
Good Answers: 58
04/02/2010 11:52 AM
My hydraulic systems salesman had a chart with pipe sizes compared to flowrates, very valuable in choosing fittings and pipe. Distance matters, too.
"Pipe" will always be the same OD for each size so it can be threaded for fittings. The ID varies according to "schedule" and determines the pressure the pipe can hold.
There is a maximum flow for fluids, and that has to be accounted for, too. For hydraulic fluid, I think it was fifteen feet per second.
mike k
Register to Reply 4 comments
mike k (1); RDGRNR (1); Tim in Mexico (1); Tornado (1)
