Previous in Forum: Electromagnet Renewable Engine   Next in Forum: PHASE CHANGE
calculation method of belt conveyer speed
04/03/2010 1:02 PM
''how do i calculate belt conveyer belt speed and also given motor data=5.5 kw/7.5hp,conveyer length- 50mtr,gearbox ratio=40:1,belt width=550mm. head pulley dia=410mm,head puley length=600mm,bulk material iron conveying,slope=16 degree.
Re: calculation method of belt conveyer speed
04/03/2010 1:12 PM
What is the rpm of the motor? Divide by 40 to get rpm of pulley. Multiply by circumference of pulley (410 * π) to get belt speed. Belt width, length, slope, and material conveyed are irrelevant, as is motor hp/kw.
Good Answers: 141
04/03/2010 6:44 PM
If no other reduction is applied, bmo Chain and Sprockets or Belts, is this for me, given no RPM of the motor, anticipated well in the answer, a correct and complete answer.
Plenty of room here
04/04/2010 1:45 AM
''how do i calculate belt conveyer belt speed and also given datas moter =5.5kw/7.5hp,moter rpm=1440,gear box ratio=40:1,belt width=550mm,belt lenth=50mtr,pulley length=650mm,pulley dia=410mm. bulk material iron ore conveying ,slope=16 degree
04/04/2010 11:30 AM
what is the ratio of the p2-67 model Elecon geaar box,type- 4stage helical,dc motor =160kw,rpm=1500.
dvmdsc (1); mukesh.parida1982@gmail (2); Tornado (1)
