Previous in Forum: car material properties   Next in Forum: Queries on Drive Shaft
1940 Ford Convertible Lights Dimming
04/03/2010 11:36 PM
I am having problems with all the lights being very dim. The 40 ford is all stock. Could it be the regulator or generator?
Thanks, ED
Re: 1940 Ford convertible
04/03/2010 11:56 PM
This is a very general response: I am unfamiliar with your vehicle.
The way the regulator works is to connect or disconnect 6/12 Vdc from the battery to the generator stator windings. The regulator makes these connections/disconnections based on the output potential of the generator. The way to tell if the problem is with generator or regulator is to to bypass the regulator function and apply 6/12 Vdc from the battery directly to the generator windings for a short period of time and observe the generator output, or headlight beam intensity. A short period of time is all you want here, because the full-on output of the generator may well be higher than the steady-state output, and you don't want to fry stuff.
Anyway, if you do this bypass and you still have a low voltage output, then the generator is bad, or the belt is loose or bad; anyway, it is generator-related. If the generator output is high, then it is good and the regulator needs your attention.
emc_c
Good Answers: 137
04/05/2010 6:00 AM
Agreed, but OP would likely need more detail about how to bypass the regulator if he doesn't know.
A good chance it's the generator brushes, and these are easy and cheap to replace.
Cheers..........Codey
04/04/2010 1:36 AM
Measure the battery voltage and the voltage of the dim devices with a volt meter. What is the system voltage supposed to be, 6v or 12v? What is the voltage rating of the dim devices? A 12v lamp will be dim on a 6v system.
Good Answers: 60
04/04/2010 4:28 AM
as mentioned by someone else.
you need to get a volt meter and
1 check battery voltage
2 check voltage at dim item there will be a few volts difference but no more than about 2/3 volts
3 you might need to check amps at dim item
4 supply more information
Re: 1940 Ford Convertible Lights Dimming
04/05/2010 8:46 AM
You are also looking at a 70 year old wiring system. It is possible that you have a wiring issue.
CARPE CRUSTULORUM!
04/15/2010 2:29 PM
You need to follow the advice that peter stated above also clean the contacts at the battery, head lamps and all grounds. On older cars it is very common for grounds to be a problem.
Why buy something if you are not interested in how it works?
Anonymous Poster (1); Codemaster (1); lbwhotrod (1); not so smart (1); peterg7lyq (1); severach (1)
