Previous in Forum: Anti theft   Next in Forum: 1940 Ford Convertible Lights Dimming
9 comments
car material properties
04/03/2010 11:50 AM
hi
can anyone tell me what material is used for normal cars door , roof etc?? And the glass used in windows or the heat transfer coefficient. I want to calculate the heat flux due to radiation and convection.
rana680
Good Answers: 60
Re: car material properties
04/03/2010 12:23 PM
doors and roof ? steel
windows ? glass
what are you asking??
04/03/2010 12:25 PM
He's asking you to do his homework.
04/03/2010 12:54 PM
This is not homework.
I am trying to find out the heat transfer coefficient and the thickness so that I can calculate the heat transferred to the car by sun if it is left in sun. I am searching for this data on net also but I m not getting anything. Btw who gets this kind of homework???
rana680
04/03/2010 1:26 PM
Put a thermometer inside and park the car in the sun. When the thermometer stabilizes, you have the answer.
"Btw who gets this kind of homework?" Engineering students.
Who gets this kind of homework?
I need to make a desalination system which should be small in size, should consume less energy and time. It should be able to desalinate 500mL of 3% by weight of sodium chloride solution at a time.
I need suggestions ,please someone help me out.
Sounds like homework to me.
Good Answers: 60
04/03/2010 1:37 PM
Good Answers: 243
04/03/2010 9:20 PM
Engineering students. Automotive engineering students.
Google UOIT automotive curricula, Or Clemson Automotive curricula.
don't forget reflectivity, and spectral transparency of glass.
also specific heat and mass of interior materials.
My guess is you will find that the thermal pick up is a function of glass area; this can be changed somewhat by reflective coatings, adding metallic gold to the glass, and other means. Law enforcement will take a dim view of many of these as they obscure the view into the cabin as the california Air resources Board recently found out.
If you read the book all corvettes are red, they have a nice discussion of this problem when they designed the "new" corvette. at 125 degress F people's a$$e$ get first degree burns if their shorts are too short and they hit the non fabric seat.
http://www.alibris.com/booksearch?qwork=235973&S=R&mkwid=SPwAl120539&mcid=3789839514&siteID=Pw2LQAj_zJk-bwm4pSAdfrW_dHorsGPoZw
milo
Good Answers: 137
04/05/2010 6:36 AM
Rana
You appear to be asking for the thermal conductivity of the materials, but this information won't help you. The heat balance is much more strongly influenced by other things. I would guess most of the input goes through the windows as sunlight (visible and infra-red, the glass stops most of the UV but that's a small part of the energy).
It will reach equilibrium temperature when the losses = the input, but these are determined much more by convection coefficients from the air inside to the body parts, and from the outside of the body to the outside air. These will be different for body parts in and out of the sun. Thermal conductivity of the materials has very little effect.
There are so many variables I doubt you would come up with anything useful if you tried to estimate. As various posters have suggested, it's better to do a test.
As an aside, something I've noticed is that a car left in the sun in the UK seems to get hotter inside than it does in say, southern Europe, though the sun is a lot stronger down there. Might be a humidity thing. Anybody agree (or disagree) with that or can comment?
Cheers.........Codey
Good Answers: 60
04/03/2010 1:45 PM
I ve just thought of anther way to keep the car cool
park in a river
Buy a motorcyle...Cool and cool ( taken from one of the links)
Good Answers: 60
04/03/2010 7:29 PM
you could try putting a second skin as used on land rover roofs
The Station Wagons saw the first expansion of the Land Rover range. Station Wagons were fitted with a "Safari Roof" which consisted of a second roof skin fitted on top of the vehicle. This kept the interior cool in hot weather and reduced condensation in cold weather. Vents fitted in the roof allowed added ventilation to the interior.
http://en.wikipedia.org/wiki/Land_Rover_Series
Register to Reply 9 comments
Codemaster (1); lyn (2); Milo (1); peterg7lyq (4); rana680 (1)
