Previous in Forum: PLC Programmer   Next in Forum: 8 bar dryer
9 comments
Peak detection when receiving a signal from a transducer
02/08/2007 12:56 PM
i am working on a project that will allow me to measure the paint thickness of composite aircraft parts using high frequency waves through a transducer. by measuring the interference of the waves after they have reflected off of the paint surface and the composite surface i can measure the difference on my oscilloscope. My objective is to make this a handheld device.what can i do to expedite this process? is there any circuit or microcontroller program that would do the detection for me? if yes where could i find such an animal?
Pathfinder Tags: peak detection
Re: peak detection when recieving a signal from a transducer
02/08/2007 1:25 PM
That sounds like a great project for someone's master's thesis. Maybe you could fund them?
02/11/2007 5:20 PM
this is my final project for my bach of science
Re: Peak detection when receiving a signal from a transducer
02/08/2007 2:44 PM
It can be done based on resistence using a digital SWR meter. There should be a resistence to thickness factor based on signal strength.
(KISS) Keep it simple, stupid
Good Answers: 120
02/09/2007 12:04 AM
I think there are a few ways of telling the thickness of coatings of various types on various substraetes.
It seems to be a mature technology that you can buy off the shelf for your application,
http://www.google.ca/search?hl=en&q=%22thickness+gage%22+%2Bcoating&btnG=Google+Search
Per Ardua Ad Astra
02/11/2007 5:21 PM
the material does not conduct electricity and therefore cannot be done by resistance
Good Answers: 120
02/11/2007 8:53 PM
well, if you use electromagnetic waves you are not going to be able to make it work. Let us say.001 inch paint. SInce paint is transparent you will not get a first surface reflection.
So it must be sound or the usual capacitive means.
So .001 : and you want to detect, say 5% of that or a variation of .00005.
That means that 1/4 wave must be 0.00005 or a full wave is .0002, since sound travels 1000 feet/second is second will hold 1000/.0002 full wavelengths = 5 Megahertz sonar. They usually send a short pulse and look for the reflection, so you want to operate at 5-10 times that frequency or 25-50 Mhz sound waves.
Seems like quite a task. WHat is the highest frequency medical sonogram?
http://en.wikipedia.org/wiki/Ultrasonography
Per Ardua Ad Astra
02/13/2007 12:52 PM
i am actually taking a sine wave and modulating it with a square wave. then i measure the difference in the peak when a maxima occurs due to interference by itself. this was published by pant and skinner in october of '06. like i said it has already been tested and i just want to make it a handheld device.
02/13/2007 12:55 PM
oops i forgot to log in ^ was me, guest
02/13/2007 1:13 PM
Just a few alternative ideas.
You would need to send out a signal and receive one. Possible applications may be an IR diode to transmit, and a photo diode to receive the reflected energy. Based on the voltage drop, or change in resistence in the photo diode. This would need to be read on a non painted part for calibration at first. This would need to be done in a black box with no light entering. Another idea would be to get a sensitive enough scale to measure the difference in weight of the painted part from a non painted one. If the paint application is pretty much constant everytime as in a powder coat application. Hopefully you will get the answer you are looking for. I'm here for some ideas. Good luck.
Register to Reply 9 comments
Anonymous Poster (1); aurizon (2); bhankiii (1); doc_gash25 (3); TLGEngrCo (2)
