I have a 305 5L eng. I replaced the radiator and hose because it was leaking and overheating before. I replaced that and now it smokes now - white smoke so I flushed radiator and no smoke now i only use water in radiator. When starting it needs gas to get it started and then it idles real erratic with knock/ping noise then after 2 mins it'll slightly smooth out. It'll stall at stop lights but starts up and is fine during cruising or high speeds but when in idle or stopped at light when giving gas it will stall.
Can anyone offer advice or tips and things I should worry about? Do I need new motor?
