Previous in Forum: Waterless Glass Cleaner   Next in Forum: Sulfurous Anhydride and Polyurea
12 comments
Anti corrosion surface finish on 1.6mm mild steel
02/08/2007 2:26 PM
What is the best anti corrosion surface finish on a 1.6mm mild steel pressed and welded assembly. In terms of life and appearance
Hot dip galvanising? If you hot dip galvanise assemblies where there is metal to metal contact between the components, will these areas be protected? Hot dip galvanising doesn't give a fantastic "aesthetic" finish though.
Powder Coating? Is the life of a powder coated component more that a hot dip galvanised one? Powder coating however, I have heard, when it gets scratched,starts to corrode on that scratch, and the paint starts to peel, unlike hot dip galvanising where the zinc around the scratched area is "sacrificed" first.
Can you powder coat over hot dip galvanising? Is there any point?
Is electrocoating as an undercoat to say powder coating an overkill?
Can electrocoating by itself be used as an effective coating?
Anodising is commonly used on aluminium. I have heard stories that it can be used on mild steel, and stories that it cannot. Which is true?
I have no practical knowledge on any of these coating procedures, I have just read a little about them.
I am a 2d/3d draughtsman of many years experience, with a mechanical engineering diploma, planning to study further. I have had a rapid prototype made and done manufacturing drawings for a client for a garden hose reel, and am not sure what surface finish to recommend in terms of cost effectiveness/approx 10 year life.
Thanks and Regards
Mike Kovacik
Joburg, South Africa
Re: Anti corrosion surface finish on 1.6mm mild steel
02/08/2007 3:58 PM
Hot dip galvanizing will provide protection against most forms of atmospheric corrosion. Paint over it to get decorative color effects.
02/08/2007 11:11 PM
Thanks
I still have a quadzillion questions?
If any metals surfaces will be touching or very close together, do you hot dip the components first and then assemble/weld or conversely assemble/weld and then hot dip? If you hot dip first then assemble/weld after,how do you coat the weld after? Can you weld on top of hot dip galvanising?
What sort of paint or painting process would be good on top of hot dip galvanising?
Is the hot dip galvanising okay as it is or does it need preparing before painting ?
What sort of life span would hot dip galvanising & painting give in the worst salt spray conditions in a coastal area?
Regards
MIke
United Kingdom - Member -
02/09/2007 5:32 AM
If you are making up a framework, I would say get all your machining ops - cutting, filing, drilling etc., done before you galvanise, then assemble your frame. If you have to galvanise an assembled part, try to avoid features such as riveted joints or folds where your cleaning medium can get trapped. It will leach out again later and trash your nicely finished item. Don't try to weld galvanised parts.
If you were designing a mild steel item for the weather deck of a ship, the most effective treatment is Aluminium spraying followed by a full paint scheme - stoving primer/undercoat/topcoat - expensive and a little over the top for garden furniture.
Zinc spraying (with full paint scheme) is also slightly more effective than galvanising in a severe environment. As an aside Cadmium plating is better (thickness for thickness) than Zinc but you wouldn't want to use that!
Hot dip Galvanising with full paint scheme should give a 10 to 20 year life in salty conditions. You should consider using an etch primer on galvanising before u/coat & top coat.
My hose reel at home is made of an aluminium frame with a moulded plastic drum so no finishing required at all!
I hope this helps.
Drew
02/09/2007 8:54 AM
My company was asked to quote a similar job for the government, involving a corrosion resistant coating for steel hand rails that would be near the ocean. They wanted a spray coating of zinc, but aluminum is also sometimes used. This would be applied by a twin-arc spray gun. Two separate spools of the metal wire are fed into the gun, and an electric arc is generated between them at the nozzle. This melts and atomizes the metal, while compressed air flows through the gun to carry the particles to the target part. As applied, the coating surface is similar to medium grit sandpaper. If necessary, something like powder coating can then be applied for cosmetic purposes.
Good Answers: 27
02/09/2007 10:15 AM
The first reply by Guest is the correct approach. All welding and fabricating operations should be completed prior to Hot Dip Galvanizing. Your problem is not that difficult. Good galvanizing requires a knowledge of the chemistry of the part to be galvanized (particularly the silicon content), proper cleaning prior to galvanizing, flux, zinc bath chemistry and the process itself. In your case, the HDG process will result in the creation of three microstructural Zn-Fe alloy layers between the steel and free Zn on the surface. The service life of the HDG is directly proportional to coating thickness (including the alloy layers). The galvanizing corrodes sacrificially to protect the underlying substrate.
The answers to all your questions about galvanizing can be obtained from the American Galvanizers Association (www.galvanizeit.org). They have several publications (printed and CD) including Technical Resource, Designing with Hot Dip Galvanized Steel, Inspection of Products Hot Dip Galvanized After Fabrication, Surface Defects, Repairs, Painting, Guides, etc.
06/17/2011 3:09 AM
- I can give you some infromation on Corrosion loss of the coated steel
It goes this way
in Severe Marine Atmosphere ( test conducted on Kure Beach N.C @ 80 foot lat)
Time for 90Grams per sqare meter Galvanised shteet
coating loss in 1 year 10 micro meter approx
55% Al - Zn Coated in 8 years 1 micro meter approx
in severe marine applications
- As far as seam welding is concerened it is not possible on Hot Dip Galvanised surface.
- Primer is used before actually coating with colour
primer does the following jobs : Primers are specialized formulations and applied
to bondthe substrate with topcoates. Selection of primers compatible with top
coat is important as primers have an important role to play.
Primers 1. Promote Uniformity of surface for the application of finish coating
2. Provide basic adhesion
3. Improve service life
4. Improve flrxibility and corrosion resistance through a carefull choice of
special resins and pigments.
5. Provide buffer zone to prevent possible undesirable reactions between
finish coat and pre treated surface.
Good Answers: 120
02/09/2007 12:01 AM
First, Anodization is a way of thickening the layer of Al2O3 that forms on the surface of aluminium. I doubt you can do it with steel. There are some alloys that can be passivated. Try a search.
The best is hot dip galanizing of the final assembly after a surface treatments that strips all rust, oxides etx to bare metal. The zinc is self healing as to small scratches that penetrate, but if you drill holes and bolt items on, you will get corrosion from those wide penetrations of the zinc protection.
As for cosmetics, a primer that adheres to zinc plus paint will work. Baked powder coating is best and most enduring, or you will have to strip and repaint often
Per Ardua Ad Astra
02/09/2007 1:39 PM
Thanks to all
Aurizon, ad016, guest, CoolHandGene, & Bluestone
It seems the answer is hot dip galvanize the welded assembly first, making sure there are no folds where the cleaning medium can get trapped.
In my case there are. I need to redesign the area where the centre rolled piece fits onto the two outer discs, so there is no touching of metal faces & a decent size gap for the cleaning medium to flow away, as well as for the hot dip galv zinc to flow into. After galvanising, a baked powder coating to give a long enduring life (10 -15 years) even in the worst coastal conditions.
It seems the anodising process is a process that commonly refers to metals such as aluminium (& titanium) only, and is not a process that refers to steel.
Aurizon, I will have a look at that www.galvanizeit.org website.
Thanks and Regards
Mike
02/09/2007 8:28 AM
just buy galv./prepainted material for making your thing, or using galvalume...see dofasco.com
02/09/2007 11:02 PM
DEar Mike
I think you can use galvanizing provided you should have an effective
pre treatement of surface ie.Cleaning with acids and then alkalies finally
water to ensure the complete oxide filim is removed from the surface
when you are doing this you are allowing to form a bonding of Zinc to the
parent metal so it will ensure long life .Important factor in any surface coating
is to have a better pre-cleaning
santhosh.K.V
AMIE (Mech)
03/02/2007 2:52 PM
MIke
Are you the same Mike Kovacik of Quinton van Graan frame and ex Lochinvar.
My email mha80634@bigpond.net.au
Drop me a line plse
03/03/2007 2:02 AM
MIke
I am not too sure whether I gave you my correct details in an earlier email.
Rgds
Mike Hall
Register to Reply 12 comments
ad016 (1); Anonymous Poster (5); aurizon (1); Bluestone (1); CoolHandGene (1); gauravvyavahare (1); Mike Kovacik (2)
You might be interested in: Powder Coating Equipment, Coating and Spray Booths
