Previous in Forum: Low Resistance Test of Contact for Power Transformer   Next in Forum: Tranformer Flux Density of Core
Electric Heat Tracing Cable
04/07/2010 4:47 AM
Dear Gents,
Good Morning,
I am new member of this group, I wish to share information & discussions...
Q1: I need the calculation formulars ( as per standards) for the selection of electric heat tracing cables ( for pipes & Tanks ).
Q2: 20QTVR2-CT this cable used for heat tracing, the Number 20 stand for.......?
Thanks & Kind Regards
Re: Electric Heat Tracing cable
04/07/2010 4:56 AM
Welcome.
A1: this sort of thing is best discussed with the cable supplier directly.
A2: it is a type of self-regulating trace heating tape, thicker and with greater watts-per-metre output than the 15 and the 10 equivalents. Again, contact the supplier directly to discuss individual applications.
Good Answers: 58
Re: Electric Heat Tracing Cable
04/07/2010 3:10 PM
Greetings Ahmed,
Answer to Question #1 - Try this web address - http://www.htdheattrace.com/pdfs/PT%20Thermal%20Design%20Guide.pdf
This should be a good place to start for a very basic explanation.
Answer to Question #2 - The 20 stands for 20 watts p/ft
As the previous poster stated, contact your local heat trace mfrs rep, they should be able to help you out with design issues.
A few manufacturers with global reach are Thermon and Tyco Thermal to name a few. You should be able to find a local rep in your area by visiting their website(s).
Register to Reply 2 comments
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
