Previous in Forum: Blackening of Fasteners by Quenching After Tempering   Next in Forum: High Temp Metallurgy Resources
Ground Flare
04/07/2010 7:51 AM
Hello sirs,
Now I am working on ground flare system modification project. One of the problem which I have been requested to look after is to define the minimum fuel gas flow rate for the LP flare to maintain enough pressure for flaring. So does anybody know how to calculate those flow?
Thanks in advance.
Re: Ground flare
04/07/2010 8:37 AM
Contact the original equipment manufacturer directly and discuss the requirements.
Good Answers: 29
Re: Ground Flare
04/07/2010 10:22 AM
This paper might help you.
Re: Ground Flare
04/08/2010 2:22 AM
There is no magic number. Follow PWS and talk to the flare tip manufacturer.
You want to achieve a near stoichiometric gas/air mixture and to sustain a stable flame in ALL weather ocnditions. The OEM should be able to model this for you.
Re: Ground Flare
04/08/2010 2:25 AM
Thank you very much for your help. What does PWS mean?
Re: Ground Flare
04/08/2010 3:32 AM
PWS = PWSlack, poster # 1
Anonymous Poster (2); enguest (1); PWSlack (1); RDGRNR (1)
