Previous in Forum: Weight of GI Flat - 50 x 6mm per metre   Next in Forum: Power suply with sag & swelled sinusoidal waveform
Generator protection
04/08/2010 3:16 AM
Hai
what type of protection is used in GENERATOR
Ths 2 all
Re: Generator protection
04/08/2010 3:18 AM
For the one for the lights on a bicycle, none at all, usually.
04/08/2010 4:00 AM
Good Answers: 244
04/08/2010 8:00 PM
The size and use of the generator are some of the key factors for generator protection selection. As already indicated in the previous comments, the generator used for bicycle light usually is without protection. But the one used in nuclear or other power plant have plenty of protections.
There are many documents available in the internet for your question. These are some of them. Read the documents from these links and you will get the answer in general.
http://www.ee.siue.edu/~smuren/ECE%20545%20Notes/Ch%2011%20-%20Generator%20Protection.pdf
http://www.gedigitalenergy.com/Multilin/notes/GET-8048A.pdf
http://siemens.siprotec.de/download_neu/applications/Masch-Prot/Generator/7UM6_Gen_Prot-Schemes_E.pdf
http://www.mantatest.com/GeneratorProtection.html
- MS
04/09/2010 11:25 PM
A numerical relay is usually one size fit all. It is generally very detailed since the risks are much higher.
Better not count the cent if the risk is many many dollars.
Register to Reply 4 comments
Jans (1); msamad (1); PWSlack (2)
