Previous in Forum: Gas pressure gauges   Next in Forum: UK Libel Law Reform - The Fight Continues
10 comments
A Formica ant
04/08/2010 4:32 AM
i have a very general or say odd question, kindly answer
whenever i tried to kill A Formica ant (red ant) by placing him on my hand(between palm and elbow) and by pressing with thumb, it always gets saved. irrespective of how hard i apply force. it get sticked in the hand for some time, but after 1 or 2 second it starts moving. i know no one will belive this but this is truth and experimented.
any answer to support my querry.
Re: A Formica ant
04/08/2010 5:38 AM
Well, Formica is pretty tough stuff .
Register to Reply Off Topic (Score 10)
Re: A Formica ant
04/08/2010 6:43 AM
At the risk of sounding insulting, perhaps this isn't so much a matter of the ant being inherently indestructable as it is your hand and thumb being somewhat abnormally...shall we say...sponge-like?
Re: A Formica ant
04/08/2010 6:57 AM
You need a hand and thumb made of Masonite! Then you could kill those Formica ants.
Register to Reply Off Topic (Score 11)
Re: A Formica ant
04/08/2010 7:02 AM
thats why i said that this is an odd topic. all the replies seems like making fun. this was my observation so i shared. no problems will find elsewhere.
Re: A Formica ant
04/08/2010 11:12 AM
Never underestimate the value of brute force. Get a bigger hammer.
Re: A Formica ant
04/08/2010 3:29 PM
Your hand is soft and has plenty of movement due to the flesh, so is your thumb, the ant is hard. Now, due to both objects in contact with the ant being soft you are not able to exert enough point force on the ant to cause it harm. When you press really hard the ant just sinks into your skin and flesh but the amount of force exerted on the ant doesn't actually increase that much (because the force is actually compressing your flesh, not the harder ant).
Try with a peanut (or similar) in your hand, and then try applying the same force but with the peanut (or similar) between a hard surface. Now try between two hard surfaces.
See the difference the same force has when applied by soft and hard surfaces?
Re: A Formica ant
04/09/2010 12:14 AM
very convincing, thanks for taking/giving a serious thought on my odd experience.
Good Answers: 150
Re: A Formica ant
04/09/2010 11:55 AM
Manas, You must understand that most people know them as wood or carpenter ants, not formica ants. Formica is a tradename of a phenolic based laminate, commonly used for countertops.
That is why people are giving you a hard time.
now to answer your question, it is because your thumb is far larger than the ant and the force is being directed around the ant by the pad of your thumb which was designed by nature to evenly spread out forces. since you cannot focus the force of your thumb on such a small area, the forces actually exerted on the ant are relatively small.
Who is John Galt?
Re: A Formica ant
04/09/2010 6:55 PM
Have you ever tried to crush a flea with your hands?
I've tried dog- and cat-fleas, and never managed to do them any damage at all by squeezing between thumb and forefinger - even while rubbing at the same time. The little buggersbeasts just hop away. Needs at least one fingernail applied against thumb or finger with great force, and sometimes doesn't have much effect unless it's between two fingernails.
Surprising how effective a chitinous exoskeleton can be as armour for small creatures.
Siphonaptera (fleas) are remarkable creatures. Like some other insects, they have a ratchet-like mechanism which is used to "wind up" their resilin springs so they can leap such relatively huge distances.
Re: A Formica ant
04/12/2010 11:29 PM
Thanks jack of all trades and rorschachs,
Yesterday i won, actually in my group(friends) no one were beleiving that this is possible(killing red ant between thumb and hand). but yesterday i found red ant and demonstrated this to all. and after pressing hard 3 times, the ant got save and so my pride.
thanks once again
Register to Reply 10 comments
Anonymous Poster (3); jack of all trades (1); JohnDG (1); lyn (1); manas_dr (3); Rorschach (1)
