Previous in Forum: A106 GR B VS GR C   Next in Forum: Plastic Foam
Checking of Oil
04/08/2010 8:28 AM
how to check that any water is there inside the oil in the gear box
regards
vasuki rao
Re: checking of oil
04/08/2010 8:51 AM
"Checking for water contamination is simple _ just check the engine oil and transmission fluid as you would normally (if you don't know how, read the car's manual). If the oil or transmission fluid is milky or chocolatey then that's a sign of water contamination."
http://www.quality-trans.com/faq/faq6.htm
http://www.bangkokpost.com/life/family/145396/checking-for-flood-damage
Re: checking of oil
04/17/2010 1:22 AM
How much water do you suspect to be in the oil? A small amount may not show with the suggestions given. The most definitive way is to send a sample to a lab that does that kind of testing. I use Blackstone Labs in Fort Wayne, IN. Check their web site for more information (wwwblackstone-lab.com).
Re: checking of oil
04/08/2010 10:04 AM
check this site
www.machinerylubrication.com
this has very useful articles on oil, contaminations, filtering etc (almost everything to do with hydraulics)
Register to Reply 3 comments
Anonymous Poster (1); himart (1); yamdankee (1)
