Previous in Forum: MOC3063   Next in Forum: Noise Problem in I Current Circuit
Electromagnets Questions
02/09/2007 7:42 AM
i am a engineering scholar making the graduation project and aim to use an electromagnet in it to pull some drawers of about 25kg weight
so i want to know
1.what is the maximum load to be pulled by the electromagnet
2.does it need cooling when operated
3.how much time can i connect it to the supply
4.what is the effect of dust and the metal suface roughness on its performance
5.what is its effect on the nearby electronic devices and motors
6.what are the precautions and any notes must be considered when using it
7.which is better to buy it or to make it
8.from where could it be bought knowing that i am in egypt "but i can call for importing"
9.about how much would it cost
10.for making it please send some information from a to z i.e.from designing according to load passing by the applid voltage and current and anded by operating and precations "PLEASE MAKE THE INFORMATION IN DETAILS BY LAWS AND NUMBERS"
HOPE NOT TO BE BOTHERING U AND THANK U VERY MUCH
Re: electromagnets
02/09/2007 8:52 AM
it can pull even in tones also but need strong current.So dont worry it will work for your application also.
it purely depends on your design concept. Normaly no cooling is require for magnets but heat sinks are needed for current transfering usinit specialy transformers and semiconductor controller (drivers).
Now a day electromagnets are available for continuous duty also.
we can also design it for above.
Normaly insulation is coded in the coil itself. So nothing will happen to system. Performance wise also it will not affect more, Your application is only lifting means no problem, at the same time continuous hammering means it may show variation.
Surely it will affect. Ex: computer screen may go dim and color may change.
Remove all electromagnetic particles away from it or keep away your magnet away from there.
you want exact load means design it. you have tollarance means buy. My sugestion is buy two and take one for your exprement and one for your learning the design and make it own in future (Because time also a consider in projects).
http://www.electromechanicsonline.com/
Better you mail them your requirement and ask it.
send a line of reply.
All the best for your project.
K.P.Mahalingam
(mahalingam_kpm@yahoo.co.in)
Electrical Engineer,
INDIA - south
Every Problem has its own solution
United States - Member - Engineering Consultant Popular Science - Evolution - Understanding
Re: Electromagnets Questions
02/12/2007 1:57 AM
The mass of the drawers is no problem at all, but the distance between the magnet and the drawer could well be a project killer.
Since the lines of magnetic force complete a "circuit" between the opposing poles, the distance at which you can apply force between the magnet and the attracted object (typically steel) is severely limited.
If the magnet is in contact with the drawer, and then you are pulling it, the task is simple, as 25 kg bond strength is trivial for an electromagnet.
More information please.
Greg
02/12/2007 5:08 AM
I thought you were supposed to do your own research and calculations for graduation projects. For example it shouldn't take you long to measure the force needed to shut the drawer... If, having done the groundwork, you need help on an individual detail, that would be fine
Anonymous Poster (1); Greg G (1); mahalingam (1)
