Previous in Forum: Transformer Question   Next in Forum: Limit of Capacitors Connected on a Transformer
Good Answers: 53
Network Video Recorders
04/10/2010 8:02 PM
I am using a 5 Mega pixel IP camera and want to remotely record high resolution, minimally compressed streaming video at 10 to 15 frames per second on a computer.
I have tried configuring the camera for direct export in .AVI and .MJPEG formats, and FTP export of .JPG files. I have also tried a couple of different NVR software packages, but I have not been able to get over about 3 frames per second. Even though the task manager shows the 100 baseT LAN use is at less than 25% and CPU at less than 40% and I have plenty of physical memory.
I would like you to make recommendations that may help me to achieve this goal.
Pathfinder Tags: CAMERA Ethernet MAC pc recorder video
Re: Network Video Recorders
04/11/2010 3:06 PM
Have you checked your camera and software manuals carefully? It may be something as simple as a default software setting that is limiting the speed (not the hardware itself). Perhaps it has a speed limit for default dial-up bandwidth that needs to be changed.
Good Answers: 141
04/11/2010 10:04 PM
Check with CYtech in Shenzhen. They have a low cost 4 channel system with USB connector. 4 video 520 lines, 2 audio.
Plenty of room here
04/12/2010 9:30 AM
ipview pro by trend net works good does just what you want
we capture the same thing here and no problems
Good Answers: 53
04/12/2010 9:40 PM
Thanks for the suggestions, the problem was caused by the ethernet network switch. It seems that a crossover has less latency!
Register to Reply 4 comments
Ace Boeringa (1); Anonymous Poster (1); dvmdsc (1); jack of all trades (1)
