A current transformer plate reads: 500:5 burden 0.5
I see my clamp ampere meter showing a current of 4 amps
When I put a different current transformer over the secondary wire (with 1:3) this coil shows also 4 amps.
The original load of the current circuit is 0.22 ohms
Can someone explain where the currents come from and flow to?:
1. From the original load, is the 4 amps to add?
2. After the second current transformer what are the loads supposed to be?
Is this a reliable way of measuring insulated from the first current transformer?
What are current, voltage, PF, expected to be in both cases?
