Previous in Forum: Block diagram of distributed control system   Next in Forum: Electromechanical instrumentation
Displacer Type Level Transmitter
04/12/2010 5:38 AM
I am in the process of selecting a displacer type transmitter. My vessel Total Inner dia is 1560 mm. Please tell me what should be the length of the displacer i should select to measure the level in this tank. Please tell me, it would be enough If I measure vessel level from 15% to 95%. PLEASE HELP ME OUT
Re: Displacer type level transmitter
04/12/2010 6:09 AM
Depends what you want to do with the level data. If you never need to know exactly what the level is when it's less than 15% or greater than 95%, then it would obviously be fine.
Don't want to seem insulting, but this seems to be a bit of a no-brainer.
Good Answers: 141
Re: Displacer Type Level Transmitter
04/13/2010 1:33 AM
We know the diameter. It is easy: without a height or a volume you don't need a length, since your vessel cannot contain any liquid. Please provide a height or volume.
Plenty of room here
04/13/2010 3:11 AM
my vessel toatal height is 1560 mm. and the process liquid is Diesel. what shold be the displacer length of displacer type LT.
04/14/2010 5:24 AM
Currently - between 15% and 100% of the 1560mm, assuming it is going in from the top. What is the height of the instrument connection above the 1560mm? Add that to the length.
Register to Reply 4 comments
Anonymous Poster (1); dvmdsc (1); JohnDG (1); PWSlack (1)
