Previous in Forum: Under ground valves   Next in Forum: B16.9 Fitting Modification
help!!!
04/14/2010 1:01 PM
please help me with this question: it mechanical engineering.. i dont understand
a mass of 0.13kg air inside a piston cylinder assembly is subjected to the following cycles of processes (a) adiabetic compression from initial condition of 1.43bar and 0.95 m^3, until half of the initial volume (b) polytropic expansion according to the law pv^1.30=c, to the initial volume and (c) a constant- volume heat transfer returning to the fluid to the initial state. sketch the p-v diagram and determine
(a) the work done by the air for each process
(b) the heat transfer for each process
(c) the change in internal energy for each process
please help me out..
This discussion was "closed" on 04/14/2010 1:12 PM. No new comments are allowed.
Message from admins:
Homework
Re: help!!!
04/14/2010 1:05 PM
Which part of your homework question do you not understand?
Better yet, tell us which parts do you understand? We will see if we can help you to understand, so you come up with the correct solutions.
Homework
